Just had a fresh install of zorin and the display is not fitting in my monitor,
Can someone help me?
Go into your settings, display and select the correct format for your display
Check the settings on the monitor itself.
Did it work fine when you used it in the live version before installing?
Yes, I switched from windows to Linux and the monitor was working fine before
I think it was because of the drivers
What kind of graphics card do you have? It could be your graphics driver
I have an intel graphics card
If that’s the case, then how do I change or update the drivers?
Check to see if there is a driver in your updates
How do I do that
You can also try in a terminal: sudo ubuntu-drivers autoinstall
In the update manager I believe it is located... I don't use Gnome anymore..
But just do a search in your menu for update.
I don’t have any driver or software updates right now
I think it had to do with my drivers, my laptop uses an intel graphic card but I don’t know why zorin decided to install AMD drivers
Try the terminal command I gave you above
I did, it said I didn’t have any drivers to install
The update manager told you that, is that what you mean?
Please relay the output of
sudo lshw -C video
