Operaing System Zorin 16 Pro working properly on my PC without problems only hardware problem switch Dual OS. Checked W7->Zorin->Restart->choose Zorin mouse and keyboard working. That is great news.
3 posts were split to a new topic: PCIe to USB addon card
Do we understand your Mouse and Keyboard problem is now solved?
If it is then please mark the post which solved it as
Solution
Yes. The best solution will be what before advice @FrenchPress and @Aravisian about buying adapter usb PCI-Express. Besides this is not problem operating system but hardware then this topic we can closed.
I don't understand after format operating system and booting dual now all working normal but my computer start slowly 1 min 20 sec
I find a solution what was a problem all time with this ports usb,not working mouse and keyboard after restart system. Don't need to buying adapter PCI Express.
The simple way just Clear CMOS and out battery. Now everything working perfectly also Linux don't gived any problems when start what i put a photo before.
here no all device recognize correctly before I have usb unknown device. With simple Clear Cmos out battery and jbat1 clear cmos jumper. First used jumper next battery out. In two words "Reset Bios"
This topic was automatically closed after 6 days. New replies are no longer allowed.
