I will soon buying adapter usb pci-express. Any advice which version to buying to working properly?
I have a couple of suggestions but as @zabadabadoo suggested, you should start a new thread for that.
[edit]
I use my moderator magic wand to warp us all to the new thread.
The PCIe to USB 3.0 add-on card I use for my Zorin desktop is this: Inateck KT4006 (2 ports)
https://www.amazon.fr/gp/product/B00JEVLEFQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
If you need more ports, Inateck KTU3FR-502U is a 7 port version.
https://www.amazon.fr/gp/product/B00FPIMICA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Both cards have Frescologic FL1100-EX chipset which is compatible with Linux (and Hackintosh I might add).
@FrenchPress To keep things tidy, I have copied part of my post back to the old thread which it related to, then deleted the post you split to here.
Ah, sorry.
It seems I also dragged your post which should have remained in the old thread.
Well, I am still a novice at my magic wand ![]()
This help many when moderator move some topic to the same problem. Very thank you. I check if my country i can get this type adapters.
Are you from Eastern Europe?
I hope there is such thing as Amazon equivalent.
Almost all my computer parts came from Amazon France and England.
I am in zone Shengen. More complicated to buying anything.
It does not necessary to have an exactly the same model.
As long as it has a Linux compatible chipset on it, you are good to go ![]()
all coming from made in China then probably all have near the same chipset.
Yup, I see some Linux compatible cards there.
Not necessary so. Some might be from Taiwan.
I wondering on the shop must be some describe what type product will be a comatibility with linux.
Yes, the first one on the list you posted, says for Windows, Mac and Linux.
May be a good idea to go to the item manufacturer or chipset provider to check what they mean by Linux compatible. It is not unheard of that some suppliers just bundle in a very old driver to make that claim.
At least it is an easy return if the claim turned out to be incorrect ![]()
I wondering if this could be a problem why my operating system start slowly 1min 20 sec but this usb also not recognize in W7 but now when I restart from linux to win 7 my keyboard and mouse working after format hard disk. I wondering it could be some software doing this problems. Good advice never install sh*t if you don't need that or asking advice if this not harm your PC. It was problem CMOS. Restart bios helped
