Hi all,
I'm an experimented linux user but new to Zorin. Been distro hopping for long time from Mandrake, Ubuntu, Debian, Gentoo, Funtoo, OpenSUSE, Arch, Manjaro, ...
I have tried the zorin 17 liveusb and fell in love with the distro. I use to be a KDE user but I find Zorin gnome interface very attractive and it can be easily customized to my liking. So I gave some money to help funding and got a nice Zorin Pro to install.
I have installed it on my laptop zorin 17 pro with encryption and ZFS (I'm new to zfs but want to learn about it at the same time
My language is french and my keyboard layout is fr_CA (I'm in Quebec city).
At boot time I get a graphic prompt to enter my passphrase. My passphrase contain some special character correctly mapped on fr_CA keyboard but not at the same place on the US keyboard. But Zorin got it right by setting my keyboard to the good layout BEFORE asking for the passphrase. But I constantly get errors entering the passphrase since I sometime hit the "caps lock" that is just over the caps key. Would it be possible that a "caps lock" warning shows on the passphrase window ? And also a "Show text" button to check what is typed would be very usefull since the passphrase is hidden.
Congratulation to the team for the nice work of putting together all pieces of a nice distribution ![]()
Regards,
BT
Some info on my laptop:
bt@zero:~$ inxi -Faz
System:
Kernel: 6.2.0-39-generic x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/BOOT/ubuntu_hwmpxp@/vmlinuz-6.2.0-39-generic
root=ZFS=rpool/ROOT/ubuntu_hwmpxp ro quiet splash vt.handoff=1
Desktop: GNOME 43.9 tk: GTK 3.24.33 wm: gnome-shell dm: GDM3 42.0
Distro: Zorin OS 17 base: Ubuntu 22.04 LTS Jammy
Machine:
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X513UA.305 date: 03/12/2021
Battery:
ID-1: BAT0 charge: 33.4 Wh (100.0%) condition: 33.4/42.1 Wh (79.3%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 75
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
CPU:
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1442 high: 1800 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400
3: 1397 4: 1397 5: 1397 6: 1397 7: 1400 8: 1400 9: 1400 10: 1400 11: 1700
12: 1397 13: 1397 14: 1400 15: 1800 16: 1400 bogomips: 57490
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: itlb_multihit status: Not affected
Type: l1tf status: Not affected
Type: mds status: Not affected
Type: meltdown status: Not affected
Type: mmio_stale_data status: Not affected
Type: retbleed
mitigation: untrained return thunk; SMT enabled with STIBP protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Not affected
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300
Device-2: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.5x7.6") diag: 395mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: RENOIR (renoir LLVM 15.0.7 DRM 3.49 6.2.0-39-generic)
v: 4.6 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Audio:
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k6.2.0-39-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: up mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 1-1.3:4 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enx00e04c68397d state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-2:5 chip-ID: 8087:0029 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 4 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.2 sub-v: 237e hci-v: 5.2 rev: 237e
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept
service-classes: rendering, capturing, audio, telephony
RAID:
Device-1: bpool type: zfs status: ONLINE level: linear raw: size: 1.88 GiB
free: 1.73 GiB allocated: 147 MiB zfs-fs: size: 1.75 GiB free: 1.61 GiB
Components: Online: N/A
Device-2: rpool type: zfs status: ONLINE level: linear raw: size: 944 GiB
free: 757 GiB allocated: 187 GiB zfs-fs: size: 914.75 GiB free: 727.19 GiB
Drives:
Local Storage: total: raw: 953.87 GiB usable: 1.83 TiB
used: 187.2 GiB (10.0%)
SMART Message: Required tool smartctl not installed. Check --recommends
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 33.9 C scheme: GPT
Partition:
ID-1: / raw-size: N/A size: 733.01 GiB used: 5.82 GiB (0.8%) fs: zfs
logical: rpool/ROOT/ubuntu_hwmpxp
ID-2: /boot raw-size: N/A size: 1.75 GiB used: 146.1 MiB (8.2%) fs: zfs
logical: bpool/BOOT/ubuntu_hwmpxp
ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 18.4 MiB (3.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/log raw-size: N/A size: 727.2 GiB used: 11.4 MiB (0.0%)
fs: zfs logical: rpool/ROOT/ubuntu_hwmpxp/var/log
Swap:
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 253:1 mapped: cryptoswap
Sensors:
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): cpu: 0
Info:
Processes: 550 Uptime: 1h 34m wakeups: 7 Memory: 15.02 GiB
used: 4.97 GiB (33.1%) Init: systemd v: 249 runlevel: 5 tool: systemctl
Compilers: gcc: 11.4.0 alt: 11/12 Packages: 2303 apt: 2231 lib: 1091
flatpak: 72 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
bt@zero:~$
