Failed to create file system during installation
Why would I need boot older version, what gone it gone.
I meant for it Zorin and it's kernel. Because you mentioned that after an update and when you restart Zorin, it goes to back screen.
There is a possibility that the update has included a kernel update but didn't get updated properly, so it resulted the black screen. Choosing older kernel grub might able to boot you into your Zorin. Then you can re-run the updates to see if that fixes your Zorin black screen issue.
What you mean? Can you move to Black screen appeared after restarted Zorin 18 - #7 by worthless please.
