Hi I have this machine running 16.2 and the following is listed via lsusb:-
Bus 001 Device 004: ID 0bda:5690 Realtek Semiconductor Corp. Integrated_Webcam_HD
Bus 001 Device 003: ID 138a:0091 Validity Sensors, Inc. VFS7552 Touch Fingerprint Sensor
Bus 001 Device 002: ID 8087:0a2b Intel Corp.
I don't have a fingerprint sensor myself, so can't check. Maybe it will be of some use to you, otherwise continue to websearch and see if anything better appears.
Thanks I did try that already and my specific model is not covered by the utility. Actually I did try probing and uploading my machine to a linux HW database HW probe of Dell XPS 13 9365 #b65d5ce654
Looks like NO ONE has managed to get this device to work according to this database.
I see that is marked "unstable", so I guess it is not yet put through to a Ubuntu LTS and thereby ZorinOS.
If you are desperate for that functionality you may be restricted to bleeding edge linux distros and all the fun of the fair that goes with them. Otherwise, just have to sit and wait.
indeed the askubuntu article is over 2 years old and aligned to 20.04 - which I understand Zorin 16.2 is based on. Perhaps when Zorin moves to 22.04 I'll be sorted I think. Looks like this sensor support is in v1.92.0of libfprint and 20.04 only goes upto v1.90 according to this
