First Layout - Maximize when dragged to top
I've noticed on the first layout, when I drag to the top it does not maximize the window and instead just resizes it to almost maximum then leaves a small gap on all sides...
I've looked through the options and can't figure a out a way to make it maximize instead, can anyone help?
Take a look here:
That did it! Thank you!
Sorry I did search and didn't come across this post :slight_smile:
You're welcome, no problem!
