Hello Zorin OS team,
I found a fontconfig issue on my Zorin OS system that caused IntelliJ IDEA and GitHub Copilot to freeze when opening the Copilot Chat/Agent UI.
System:
- Zorin OS 18
- Ubuntu 24.04 (Noble) base
- GNOME Shell 46
- IntelliJ IDEA Ultimate 2026.2.3
- GitHub Copilot plugin 1.18.0
Problem
GitHub Copilot was stuck at:
"Loading / Initializing Copilot..."
IntelliJ itself worked normally when Copilot was disabled.
After taking a Java thread dump, the AWT Event Dispatch Thread was found blocked while creating the Copilot Compose/Skia UI:
org.jetbrains.skia.FontMgrKt._nDefault
androidx.compose.ui.text.platform.FontCache
androidx.compose.ui.text.font.SkiaFontLoader
com.github.copilot.agentHarness.ui.ComposeBackgroundAgentPanelFactory
com.github.copilot.chat.window.CopilotChatToolWindowController
I initially investigated Copilot configuration, MCP, GPU/JCEF and network issues, but none of those resolved the problem.
Fontconfig investigation
Before the workaround:
$ fc-match sans-serif
OpenDyslexic-Bold.woff: "Arimo" ""
$ fc-match "Noto Sans"
OpenDyslexic-Bold.woff: "Noto Sans" ""
$ fc-match "Arimo"
This seemed unusual because the system was configured to use Noto Sans, but Fontconfig was selecting OpenDyslexic-Bold.woff for generic and named font requests.
Zorin package information
The OpenDyslexic font is installed through the Ubuntu/Debian package:
fonts-opendyslexic
And on my system:
$ apt-cache depends fonts-zorin-os-core | grep -i opendyslexic
Recommends: fonts-opendyslexic
$ apt-mark showauto | grep -E 'fonts-opendyslexic|fonts-zorin-os-core'
fonts-opendyslexic
fonts-zorin-os-core
So both packages are installed automatically.
Workaround
I temporarily moved the OpenDyslexic WOFF files out of the active font directory:
sudo mkdir -p /usr/share/fonts/woff/opendyslexic.disabled
sudo mv /usr/share/fonts/woff/opendyslexic/*.woff
/usr/share/fonts/woff/opendyslexic.disabled/
sudo fc-cache -f
After this:
Arimo-Regular.ttf: "Arimo" "Regular"
Then I added a Fontconfig configuration to explicitly prefer Noto Sans for generic sans-serif requests.
After rebuilding the cache:
NotoSans-Regular.ttf: "Noto Sans" "Regular"
$ fc-match "Arimo"
Result
After correcting the Fontconfig font selection, IntelliJ IDEA and GitHub Copilot work normally.
Importantly, I can now launch IntelliJ normally without:
SKIKO_RENDER_API=SOFTWARE_FAST
JCEF_DISABLE_GPU=1
and Copilot still works correctly.
Conclusion
I don't know whether the root cause is the OpenDyslexic font itself or a Fontconfig configuration/aliasing issue.
The reproducible part is that Fontconfig selected:
for:
- sans-serif
- Noto Sans
- Arimo
and correcting the font selection completely resolved the IntelliJ/GitHub Copilot UI freeze.
Could you please investigate whether the Zorin font configuration or the fonts-opendyslexic package integration can cause this behavior?
I would be happy to provide the full thread dump, fontconfig output, or any additional diagnostics if needed.
fc-match -v sans-serif | grep -E 'file:|family:|style:'
/usr/share/fonts/woff/opendyslexic/OpenDyslexic-Bold.woff
