glxinfo -B
sudo lshw -c video
glxinfo -B
sudo lshw -c video
:~$ glxinfo -B
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: AMD (0x1002)
Device: AMD Radeon (TM) R9 390 Series (HAWAII, DRM 3.40.0, 5.11.0-36-generic, LLVM 12.0.0) (0x67b1)
Version: 21.0.3
Accelerated: yes
Video memory: 8192MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 4.6
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
VBO free memory - total: 7350 MB, largest block: 7350 MB
VBO free aux. memory - total: 8113 MB, largest block: 8113 MB
Texture free memory - total: 7350 MB, largest block: 7350 MB
Texture free aux. memory - total: 8113 MB, largest block: 8113 MB
Renderbuffer free memory - total: 7350 MB, largest block: 7350 MB
Renderbuffer free aux. memory - total: 8113 MB, largest block: 8113 MB
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 8192 MB
Total available memory: 16384 MB
Currently available dedicated video memory: 7350 MB
OpenGL vendor string: AMD
OpenGL renderer string: AMD Radeon (TM) R9 390 Series (HAWAII, DRM 3.40.0, 5.11.0-36-generic, LLVM 12.0.0)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 21.0.3
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.0.3
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.0.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
*-display
product: Hawaii PRO [Radeon R9 290/390]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:02:00.0
version: 80
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=amdgpu latency=0
resources: irq:48 memory:e0000000-efffffff memory:f0000000-f07fffff ioport:e000(size=256) memory:f7e00000-f7e3ffff memory:c0000-dffff
lscpu
Architektura: x86_64
Tryb(y) pracy CPU: 32-bit, 64-bit
Kolejność bajtów: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU: 8
Lista aktywnych CPU: 0-7
Wątków na rdzeń: 2
Rdzeni na gniazdo: 4
Gniazd: 1
Węzłów NUMA: 1
ID producenta: GenuineIntel
Rodzina CPU: 6
Model: 60
Nazwa modelu: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Wersja: 3
CPU MHz: 800.000
CPU max MHz: 4400,0000
CPU min MHz: 800,0000
BogoMIPS: 7999.57
Wirtualizacja: VT-x
Cache L1d: 128 KiB
Cache L1i: 128 KiB
Cache L2: 1 MiB
Cache L3: 8 MiB
Procesory węzła NUMA 0: 0-7
Vulnerability Itlb multihit: KVM: Mitigation: VMX disabled
Vulnerability L1tf: Mitigation; PTE Inversion; VMX conditional cache flushes, SMT vulnerable
Vulnerability Mds: Mitigation; Clear CPU buffers; SMT vulnerable
Vulnerability Meltdown: Mitigation; PTI
Vulnerability Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl and seccomp
Vulnerability Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2: Mitigation; Full generic retpoline, IBPB conditional, IBRS_FW, STIBP conditional, RSB filling
Vulnerability Srbds: Mitigation; Microcode
Vulnerability Tsx async abort: Not affected
Flagi: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopolo
gy nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm
cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid xsaveopt dtherm ida arat pln pts md_clear flush_l1d
From this command all is installed properly?
^ Yes.
Then now only guide what next after installed Zorin 15 guide.
With this command Zorin don't have "Pro"?
lsb_release -a
No LSB modules are available.
Distributor ID: Zorin
Description: Zorin OS 16
Release: 16
Codename: focal
It is possible download image iso Zorin with kernel 5.11.0-34?
I created fresh install and was 5.11.0-27 after update my kernel go up 5.11.0-36 and many things not working.
I don't know why because when I bought Zorin 16 Pro the stable kernel was Zorin 5.11.0-34 generic.
Whenever you download a Zorin OS ISO, its always going to have the latest kernel version approved by the developers. In this case, the latest version is 5.11.36, so the answer is no, you can no longer download with a lower version.
I have a hardware question for you as I am curious Bourne. I noticed that your CPU is operating at 4.4GHZ, thats a high SPEC, I know, cause my comptuer can do it, and even higher then that if necessary.
The question I have is, what kind of cooler do you have on that CPU to cool that beast running at 4.4GHZ?
https://www.qihaobuy.com/item/cooler-master-t400-pro-computer-cpu-cooler-dual-120mm-fans-lga-2011-1150-1151-amd-am4-quiet-desktop-pc-cpu-cooling-radiator-fan/ here is cooler cpu
also using Noctua front and back
Well that explains it, you got a nice cooler on there keeping that CPU from melting down. Good deal Bourne! I remember you posting your thermals not that long ago from Psensor. And if I remember correctly, you were no higher then 50C.
Yes I liked cpu fan from water cooling because they can fast cooldown temperatures.
For me a computer is like a baby.
Cleaning often from some dust. Checking everything. Dust could kill your usb ports or ports on motherboard.
Here is my a cabinet.
Video is from 2014 then you can wondering how old my pc.
Water cooling:
PROS...
Can effectively cool more efficiently.
Superior cooling for overclocking.
Often times quieter then standard fan setups.
CONS...
Loss of cooling performance after 2-years due to permeation.
Depending on coolent used, could errode insides causing leaks.
Water cooling setups are expensive.
Your computer is your baby. Awwww Thats how I feel about my MSI computer. Your computer case demands dominance, cause that is what it looks like its doing there lol.
Yes but I am addicted with good quality PC.
If I would choose again PC then I get Lian Li some E-AXT version.
Another side if still my PC is working then why a changing?
I know my PC for normal using is ok but some a games don't working that is diffrents. For internet, e-mail and simple testing linux distrowatch is very cool.
I saw you have a POP OS on gaming MSI. I could try on next external hard disk.
This is very cool if you want something else just connect a pendrive or external hard disk and everything working.
I did the same, zorin os is installed on internal disk. Pop! Os on external. Love it!
Popcorn i installed very cool dash example and gnome extensions.
