Where I can get, Please use the .deb package to install Network Displays
I apologize... Apparently there is not a .deb package for it... I just looked:
https://pkgs.org/download/gnome-network-displays
Very well...
We can do it the old fashioned way:
Install necessary packages and dependencies:
sudo apt install ubuntu-restricted-extras python3-pip gettext appstream-util cmake libgtk-3-dev libnm-dev libpulse-dev nasm git gstreamer1.0-plugins-bad libgstreamer-plugins-base1.0-dev libgstrtspserver-1.0-dev
sudo pip3 install meson ninja
Make a new folder to hold your download and install:
mkdir ~/src && cd $HOME/src
git clone https://github.com/cisco/openh264 && cd openh264
make
sudo make install
cd ..
git clone https://github.com/benzea/gnome-network-displays && cd gnome-network-displays
meson build
cd build
ninja
sudo meson install
Assign permissions:
pkexec env DISPLAY=$DISPLAY XAUTHORITY=$XAUTHORITY NETWORK_DISPLAYS_H264_ENC=openh264enc /usr/local/bin/gnome-network-displays &
In that case, we have tried all I can think of Zorin OS side. I can only suggest you make a bug report with the Developer:
Is there any alternative app for this bro
I do not know enough about alternatives to make a sound recommendation. You might do a net search and read the reviews on each application.
Bro I have searched in Internet but there are no proper results.
No solution for this
Perhaps @StarTreker on here can help. The Treker has connected TV to Zorin OS successfully in the past.
Thank you, bro, excellent support from your side I'm happy about that.
Marked Solution. 377
