grub-install --target=x86_64-efi --bootloader-id="Void Linux [GRUB]" --no-nvram /dev/sda2
That would be the terminal command to use Grub-Install to install grub onto the drive partition pictured in your screenshot above.
What about
sudo apt install grub-efi
That message means that in LiveZorin, the source for installing is currently from the USB packages.
Are you able to connect to the Internet in Live Zorin?
Im connected
This may seem silly... But
sudo apt update
Already finished, i reboot?
Sorry was called away for work.
Where does your installation stand at this time?
Crashed or what do you mean?
I think the problem is the path, since it installs it in dev / sda, but it shows me that only dev / sda1 and dev / sda2 exist
/dev/sda is the Drive.
/dev/sda1 and sda2 are partitions on the drive.
I take it from the above response that the installer still is crashing and installing the rest was a no-go?
Usually, if the installer crashes at Grub Install, you can just do the grub-repair after. I have never once seen grub-repair fail.
So there is no solution?
It could be something simple that will make us facepalm when we realize. But for the moment, I am stumped.
Can you walk me through what procedure you took when you installed?
Did you choose "Something else" or "Install Zorin alongside" or "Erase disk and install..."?
Erase Diks and Install.
This had already happened to me with Mxlinux and Debian. The problem is the grub since this model had an agreement with Windows or something like that and has the NVRAM blocked in read-only, but in Zorin I don't know how to remove it
You were typing as I was - we both were researching.
I also found this little gem:
Which has some good step by step instructions, too.
DonAjolote's point about NVRAM is the much needed clue to the puzzle.
Thanks for finding this.
Exactly what I have discovered:
The Acer Insyde H2O BIOS is broken, so as soon as it runs efibootmgr to create a boot entry,
Now if only my husband let me touch his "score reader (Acer Switch 3)"....
