Hello, my grub menu's resolution looks kinda off(it's stretched). How to fix it?
Specs
OS: Zorin OS 16 x86_64
Host: Aspire S3 1.15
Kernel: 5.11.0-27-generic
Uptime: 22 mins
Packages: 1919 (dpkg), 16 (flatpak)
Shell: bash 5.0.17
Resolution: 1366x768
DE: GNOME
WM: Mutter
WM Theme: ZorinBlue-Dark
Theme: ZorinBlue-Dark [GTK2/3]
Icons: ZorinBlue-Dark [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i5-2467M (4) @ 2.300GHz
GPU: Intel 2nd Generation Core Proce
Memory: 2441MiB / 3784MiB
Try by first pressing c while grub is running to enter the console.
run
videoinfo
depending on your grub this may not work, if not run
vbeinfo
You're looking for a value labeled "preferred mode"
Once you have this value you have to edit the grub file to reflect this change.
Complete your boot into Zorin then open a terminal.
Run this command to open the grub configuration file.
sudo nano /etc/default/grub
then change the line starting with
#GRUB_GFXMODE=defaultxresolution
to:
GRUB_GFXMODE=supportedxresolution
exit nano and save changed before lastly running
sudo update-grub
which will update grub to reflect this change.
both vbeinfo and videoinfo doesn't work. My screen resolution is 1366x768
It doesn't work, I also realized that the grub screen on my other pc with Zorin Os 16 is different and looks excellent.
Does the grub menu look like the Zorin OS Theme as seen on the other machine?
Are you attempting to run these commands once Zorin is booted? These must be run on grubs command line which can be gotten to by pressing C when grub is open prior to loading Zorin.
I changed the #GRUB_GFXMODE=640x400 to 1366x768
The i sudo update-grub
It still looks stretched and blurry.
Did you remove the # at the beginning of the line? this denotes a comment so if you didn't remove this then this change did nothing.
oh so # just ignores the command, I didn't know that. But it still looks blurry
One more thing the Manufacturer logo is supposed to be shown above the zorin os logo when booting right?
No, the manufacturer logo will appear on the Motherboard splash screen at boot. The Zorin Logo splash screen begins at Zorin OS initialization.
Interestingly enough, my system actually does show my motherboard manufacturers logo above the Zorin logo during boot. This was not my experience in any prior version of Zorin or any other Ubuntu derivative in the past. This is likely some sort of grub configurable option though that could be easily changed.
One of my computer shows the logo on zorin os boot and one doesn't.
I don't think its a grub thing i think its a gnome thing, cuz when i ran fedora gnome it has logo on the fedora logo.
More than just interesting... I'm not even sure how that is possible...
This is different from how I interpreted the posts above:
I read them to say that the Manufacturer logo is appearing above the Zorin Logo - On the Same Splash Screen. Which would surprise me in many ways... Perhaps I am completely misunderstanding what they meant.
The motherboard splash and the Plymouth wait service are separate and distinct entities.
Mind.... blown... Just shows how little I know.
Really bad picture quality here so pardon that, but you can clearly see the motherboard manufacturer MSI's logo and the Zorin logo below. Like I said in my previous response, this is the first time I've ever seen this, but now I'm leaning towards it not being a grub option and being more likely something to do with Plymouth wait service since this occurs after selecting Zorin OS on the grub menu
I wonder if this is why the Z16 Logo Splash is positioned at the bottom of the screen. I did not like it- so reverted to the Z15 Plymouth theme.
I also want to revert the grub theme and the splash screen. I don't like the zorin os all black and white grub screen. Can tell me how?
