hi dear zorin os support
i have a problem with zorin os pro
When I click on the dep files and want to install the file, it enters the software program and says loading the details of the program and does nothing. pls help me
First try these solution: Fixing the common problems of Software Center
Other way you can install a deb file using the terminal using the following command:
sudo apt install /path/to/deb
Replace /path/to/deb with actual path to your deb file. If you are unsure of the path-to-deb then simply drag n drop the deb file to the terminal window.
You could use for Installation a Program called GDebi.
