I won't go into my full history with Linux as it's a bit long. I'm currently using Manjaro because it simpler than Arch.
Recently I ran into an issue with installing Foxit Reader on Manjaro. The package for Foxit Reader in AUR is simply outdated. Can't blame anybody, Foxit decided to discontinue support for Linux. I wasn't able to download it from the official website.
My question to you guys. Is Zorin OS uses synaptic manager like Ubuntu? What is your experience with Zorin OS package manager?
In particular, are you able to install Foxit Reader from Zorin repositories?
In general, I've looked into reviews about Zorin OS and what I've seen appealed to me, at least in a visual sense. I've also looked into Zorin performance which is also speedy enough.
Synaptic isn't preinstalled but You can install it easily with the Terminal Command sudo apt install synaptic
Instead of Synaptic You can use the Terminal directly with APT, too. If You shouldn't like the APT Interface, maybe Nala could be something. This is a graphical Frontend for APT and delivers a more structural Overview. You use the same Command but instead of apt You type nala. Some Examples:
As a standard pdf reader Evince is OK, but certainly not as versatile as Okular which can even display presentations and has a presentation slide tools (appearance/slide numbering). Whilst ms-edge browser might appear nice, underneath it is likely to be data-scraping and potentially selling your browser habits to its 801 partners like it does with Outlook.
