1st issue is:
I can't get the Internal IP address to display inline. It will only show on the next line no matter what I do. Even if I remove the word "Internal IP and use a single character, it still defaults to the line below.
2nd Issue
Is there any way to change the color of live cpu usage and data transfer boxes ?(the white and blue inside showing usage, not the box itself) Which file? It doesn't seem to be called from the widget script.
Yes, we can solve both issues.
It would be a lot easier on me if I have the full conky that I can load and tease out while running it.
Can you provide that (you can use pastebin.com)
Changing the color of elements is very easy - you can see in your snippet
You can define as many colors as you want, really... So you can add a color4 or a color5... Or alter one of the existing ones.
Once you have the colors defined as above, you can use the tag ${color(NUMBER)} in front of each and any element you wish to define a distinct color for.
For example;
The total file size for this conky is 43 MB. Best just to give you the direct link where I got it from.
Maybe I did not explain this well.
I'm pretty versed with Conky and know how to change/add color elements as I have already fully customized it.
The elements you are quoting in the script only change font color and line color. I want to change the color of the live feed inside these boxes (the white and blue). Not the box outline.
I cannot find where in Conky this live feed is being being formatted for color as it is not defined in the widget itself.
As for the Internal IP inline issue, I'll wait for you to install the conky to see if you can find what strange magic is forcing it onto the next line.
Yes, the example I gave was merely an example.
The color is set for the output the same way.
As another example from my own conky: ${alignr}${color1}[${color} ${fs_bar 5,120 /} ${color1}]${color}
Default
But again, it only added a pink outline (which I don't want) while the live feed is still white and blue (which I want pink). Because there are 2 colors in that feed, I really think it is being formatted somewhere else in Conky outside of this widget script, but for the life of me can't find where.
EDIT: Pretty sure it is... I grabbed the script itself and created a new conky on mine named tinks-test
and sure enough... the Internal IP: line is dropping down one line on mine, too.
I'm working on solving...
Weird, as soon as I did that the internal ip address disappeared and it now says no address: WLAN
I literally removed the one line of space, nothing more.
More frustrating is that I cannot just comment it out to hide it. The entire script breaks. I really only need the external ip.
$voffset is vertical offset so you're saying move this up one line, alignr is right align this is so it doesn't appear over the internal Ip text then we are adding a vertical offset back down so it doesn't offset everything else in the script further on
