Heres a great script for customizing zorin by Rob Braxman
I want to share with you people beginners and advanced what ever your skill level
rob has an incredible amount of tech knowledge to share and hes a very reliable source.
check his videos out hardware software opsys.
im not endorsing him i just realise that zorin os is a beginner level operation system.
so most new users have no idea that it has a terminal which is the real power of zorin
so if you want learn more and griow intellectually check out some of robs linux stuff.
ive reposted the following linux script of robs that really changes alot of things for the better in zorin. thertes also a undo script so you vcant go wrong.
check it out. and download the required files : GitHub - robbraxman/readylinux: This is a script to correct the common usability issues in Linux and will improve the Linux desktop experience for both new and advanced users. This will be a community effort and a work in progress. · GitHub
follow the instructions pretty easy.
Rob Braxman
https://www.youtube.com/results?search_query=rob+braxman
Linux Is a Pain. Let's Fix It.
These are usability problems that show up on almost every distro. A new user hits one, decides Linux cannot be changed, and goes back to Windows.
The fix is one script. Run it once after a fresh install. It is a compilation of long use, plus the easy privacy setup, not a new distro. Nothing here is destructive. uninstall.sh reverses the pieces that are not already in Settings.
Advanced or beginner, you can see what each change does before you rely on it. The idea is the same kind of script Chris Titus uses for Windows. This one is for Linux.
Supported
Ubuntu GNOME
Zorin
Linux Mint Cinnamon, MATE, and Xfce
Pop!_OS COSMIC, and older Pop still on GNOME
Fedora Workstation
Install
The first run is the one time you need a terminal. After that, package files, AppImages, and .sh files can be opened from Files.
wget -qO- https://raw.githubusercontent.com/robbraxman/readylinux/main/install.sh | bash
You are asked for your password once. The rest is automatic. The script does not restart logind.
Undo the script changes:
wget -qO- https://raw.githubusercontent.com/robbraxman/readylinux/main/uninstall.sh | bash
Uninstall does not remove apps. It removes the Media and AppFiles links, the Files favorites, the IPv4 default, and the lid-close rule. Dock, wallpaper, and other visual choices stay. Change those in Settings.
The script location is fixed and can be versioned. Run it first on a new install. Suggestions belong in the Brax.me community.
  1. App installation
    Deb files, on Ubuntu, Zorin, Mint, and Pop. A downloaded .deb often opens in File Roller, the archive tool, so a double-click does nothing. The script installs GDebi and points .deb files at it. Double-click, and it installs. Leftover .deb files are linked under ~/Documents/AppFiles/debs.
RPM files, on Fedora Workstation. Fedora does not use debs or GDebi. A downloaded .rpm is linked under ~/Documents/AppFiles/rpms and opens in GNOME Software. The script installs the Fedora packages with dnf, and Chrome from Google's .rpm.
AppImages. There is no installer. You are expected to move the file, chmod it, and remember the folder. The script copies an AppImage to ~/Documents/AppFiles and adds a Show Apps launcher. This is the same on every supported distro.
Flatpak by default. Snap hides files. An OBS recording does not land in Videos. It lands under ~/snap. The script installs Flatpak and Flathub so new apps can come from there. Snap stays installed on Ubuntu. Fedora does not ship Snap, so AppFiles there is Flatpak only unless Snap was added by hand.
  1. Click a .sh file
    Files opens a shell script in the text editor. The beginner path is cd, chmod +x, and ./script.sh. The script replaces that opener with a window: Run or Edit. Run sets execute permission and starts a terminal, where a password can be entered. Edit opens the text editor. The file does not start until you press Run.
  2. Where is my media?
    A USB stick or extra partition may be mounted under /media/$USER or /run/media/$USER, or not mounted at all. The script links those disks under ~/Media, in the home tree with Documents and Videos. A watcher refreshes the links when a drive is plugged in. Files gets a Media bookmark. A phone shows up under Media too.
  3. Where are the app files?
    Snap and Flatpak files are linked into ~/Documents/AppFiles, and that folder is bookmarked in Files. OBS output is linked at ~/Videos/OBS, which is where a recording should be.
  4. Find my file
    Show Apps gets Find my file. It searches your user folders, including Documents, Media, and AppFiles. It does not search system folders. This is a GUI Search tool.
  5. Browser isolation
    Google sites stay in Chrome. Everything else stays in Brave, where you are not logged into Google. Firefox stays installed as the spare browser. The script installs Chrome and Brave if they are missing. If they are already installed, it leaves them.
  6. Needed apps
    KeePassXC, for passwords and encrypted notes.
    KolourPaint, a simple Paint-style app. Not GIMP.
    Brax.me, a Show Apps launcher for the community.
    VLC, so common media files play.
    Firefox, Thunderbird, and LibreOffice are already on most of these distros. The script fills the gaps.
  7. Defaults and pins
    mailto opens Thunderbird. The dock or menu pins Brave, Chrome, Firefox, Thunderbird, KeePassXC, Writer, the text editor, Files, Calculator, and Terminal. The names match the desktop: Nautilus and Text Editor on Ubuntu and Zorin, Nemo and xed on Mint Cinnamon, Caja and Pluma on Mint MATE, Thunar and Mousepad on Mint Xfce, COSMIC Files and Edit on Pop. Fedora Workstation uses the same GNOME pins as Ubuntu. VLC is the default for mp4, mkv, avi, and webm. The common codecs are installed so those files are not missing a decoder.
  8. Look like other desktops
    Ubuntu's dock starts on the left. On Ubuntu, Zorin, and Fedora Workstation the script moves it to the bottom, centered, with an icon size for the screen, and only if you have not already moved it. Mint and Pop keep their own panel or dock. The stock wallpaper is replaced only if it is still the distro default. Screen scale is set from the resolution if you have not already changed it, so text is not tiny. Terminal colors and size are not changed automatically.
  9. System settings
    Lid close. Settings has no useful control. On AC power the lid does not suspend. On battery it does. The system part applies on the next reboot.
IPv4. On a dual-stack network the machine prefers IPv4, so IPv6 is not the path used for tracking or a VPN leak. This is the normal home default, including Starlink CGNAT. An IPv6-only network, such as some hotel or airport Wi-Fi, can be exempted per connection in Network Manager. It is not a permanent block.
I'd rather stay away from it. It leaves quite a mess on the system, and - more importantly - the uninstaller doesn't undo everything. The reports so far, especially for Zorin, don't look good, and I've taken a look at what the script does. It makes me cringe, because I don't think there's any way to control the installation of the things you don't want.
pblanton has suggested a selective installation script which may be a bit better, but I'm not going to test those scripts.
The problem of automation like this is it was made by the user for is own habits and desktop, so you are right to stay way from :wink:
I have everything I need so far on Zorin, but have you any ideas on the scripts needed for user privileges on Ubuntu Touch ? That and mounting the SD card ? :folded_hands:
which ones do you recommend removing from the script
I like Braxman, but I wouldn't use this script. It's "opinionated," meaning that it was made for how Rob likes a desktop to be setup, as @Nourpon mentioned above. After a few years of using Linux, I've found the setups that work for me.
I would find it more useful to tell people "Here's how you can tweak a vanilla GNOME DE to look and feel more like a traditional one" and then show them how to install extensions (or just install KDE and be done with it). Or "Here are some great programs to begin with" and then show them how to install software in their distro. I think that would be more useful in the long run because people could learn to tweak their desktop in the ways that work for their workflow.
good advice im not a linux guru im a software engineer but ive been bored lately. but thank you for input well appreciated
