- Download the package from link.
- Move it to /var/lib/flatpak/runtime
- Unpack the package
wifi is pretty slow so if it doesn't download tonight ill do it tommorow but i will try to do it now
okay.
i can't put it into the folder it doesn't let me
as I wrote earlier you need to start nautilus with superuser
sudo nautilus
i don't understand what u mean
run the command and you can move/edit/change things outside of your home directory. It give you the super powers to alter the core of the OS by point and click. but be careful.
sudo nautilus
very nice command ill be sure to fix it when i get home in about 40 mins
sudo: nautilus: command not found
oh right you're on lite, try instead;
sudo thunar
I think it's that as I'm not having lite install at the moment.
what next
Lets see if it wil install now.
sudo flatpak install io.github.jeffshee.Hidamari
alright i have the app now thank you
but bro i can't have desktop icons
Didn't knew that. I don't use desktop icons.
oh i guess i might not use it in the end
Or get used to not using the Desktop as a launcher.
i could never idk why
Old Windows habit I guess. I like a clean Desktop and put stuff in the menu and files in the right folders.
Here's a screenshot of it;
that is actually really good
