So I went to check for updates today from Software Updater, and it kept failing.
So I ran my updater bash script, and it gave:
Err:9 http://ppa.launchpad.net/zorinos/apps/ubuntu focal InRelease
Could not connect to ppa.launchpad.net:80 (185.125.190.52), connection timed out
Err:10 http://ppa.launchpad.net/zorinos/drivers/ubuntu focal InRelease
Unable to connect to ppa.launchpad.net:http:
Err:11 http://ppa.launchpad.net/zorinos/patches/ubuntu focal InRelease
Err:12 http://ppa.launchpad.net/zorinos/stable/ubuntu focal InRelease
Reading package lists... Done
Building dependency tree
All packages are up to date.
W: Failed to fetch http://ppa.launchpad.net/zorinos/apps/ubuntu/dists/focal/InRelease Could not connect to ppa.launchpad.net:80 (185.125.190.52), connection timed out
W: Failed to fetch http://ppa.launchpad.net/zorinos/drivers/ubuntu/dists/focal/InRelease Unable to connect to ppa.launchpad.net:http:
W: Failed to fetch http://ppa.launchpad.net/zorinos/patches/ubuntu/dists/focal/InRelease Unable to connect to ppa.launchpad.net:http:
W: Failed to fetch http://ppa.launchpad.net/zorinos/stable/ubuntu/dists/focal/InRelease Unable to connect to ppa.launchpad.net:http:
W: Some index files failed to download. They have been ignored, or old ones used instead.
Well, there's a reason for that...
To resolve this dilemma, we’ve added a new ppa.launchpadcontent.net domain name which supports both HTTP and HTTPS (and similarly private-ppa.launchpadcontent.net for private PPAs, which as before is HTTPS-only).
add-apt-repositoryin Ubuntu 22.04 will use the new domain name by default.The old names will carry on working indefinitely – we know they’re embedded in lots of configuration and scripts, and we have no inclination to break all of those – but we recommend moving to the new names where possible. ppa.launchpad.net will remain HTTP-only.
Apparently, "indefinitely" has come and gone... or they're having problems with the old setup.
You can fix it by opening Software Updater, letting it go through its usual flagellations as it checks for updates, then clicking the Settings button, and navigating to the Other Software tab.
Everywhere in that list where it says http://ppa.launchpad.net, select that line, click the Edit button, then change it to https://ppa.launchpadcontent.net.
Don't change the rest of each line, just substitute https://ppa.launchpadcontent.net for http://ppa.launchpad.net in each line.
Note the change from http to https.
Now it shows:
echo Updating; sleep 5; sudo apt update; sudo apt upgrade; sudo apt full-upgrade; sudo apt dist-upgrade; sudo apt-get upgrade; sudo fwupdmgr refresh --force; sudo fwupdmgr update; sudo flatpak repair; sudo flatpak update; sudo snap refresh; sudo apt autoremove; sudo apt autoclean; sudo apt autopurge; sudo apt update --fix-missing; sudo apt install --fix-broken; sleep 15
Updating
Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:3 https://packages.zorinos.com/stable focal InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:5 https://packages.zorinos.com/patches focal InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:7 https://packages.zorinos.com/apps focal InRelease
Hit:8 https://packages.zorinos.com/drivers focal InRelease
Hit:9 https://ppa.launchpadcontent.net/zorinos/apps/ubuntu focal InRelease
Hit:10 https://ppa.launchpadcontent.net/zorinos/drivers/ubuntu focal InRelease
Hit:11 https://ppa.launchpadcontent.net/zorinos/patches/ubuntu focal InRelease
Hit:12 https://ppa.launchpadcontent.net/zorinos/stable/ubuntu focal InRelease
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Updating lvfs
Downloading… [***************************************]
Successfully downloaded new metadata: 0 local devices supported
Devices with no available firmware updates:
• HP TrueVision HD Camera
• ST500LM034-2GH17A
• System Firmware
No updatable devices
sudo: flatpak: command not found
sudo: snap: command not found
Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:5 https://packages.zorinos.com/stable focal InRelease
Hit:6 https://packages.zorinos.com/patches focal InRelease
Hit:8 https://ppa.launchpadcontent.net/zorinos/apps/ubuntu focal InRelease
Hit:9 https://packages.zorinos.com/drivers focal InRelease
