It just showing appearing on my 2nd monitor. How to hide them?
Screenshot: Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
Try to turn off the Home Button's in Zorin Appearance < Desktop in bottom right corner of the start button.
I want to show only Home Folder, mounted volume and Trash. That options will hide everything
Were all of them Present during the Install?
No. After I reboot my system, it just appeares
Then you should definitely turn that option off from the appearance. An add the Home Directory shortcut to your Taskbar. This will be an easy solution rather than wasting time finding solutions for hours ![]()
If you talking about untick the Home button, that dosen't help. It keep showing
Check these:-
Did you even check the screenshot?
yeah ![]()
That link you send me only hide folder called Home. Not Documents, Downloads, Public, Templates, Pictures, Videos, snap, Music, VirtualBox VMs, steamvr and Steam
That's Actually odd, Can you Delete them using Shift + Delete?
If I do that, it will also delete inside the /Home folder itself and unable to access it
Try These, Maybe this will help you Hide the Icons ![]()
No, nothing happend when I found gsettings set org.gnome.desktop.background show-desktop-icons false on Terminal
Also, Have you tried the extension part in the Link?
The easiet way would be to install the package.. gnome-shell-extension-prefs
Once you install the package, you can find the app in all apps..
and then turning off the switch for "Show the personal folder in the desktop"
Same thing can be achieved with gnome-tweaks also, If you already Installed gnome-tweaks
It's not even showing up "Show the personal folder in the desktop"-options in the Extensions Program
Then Try Gnome Tweaks an also add the universal repository and other stuff!
Are you using Zorin OS Core or Zorin OS Lite?
I'm using Zorin OS Pro
