As the title says. in zorin lite there are more options but in gnome I can't find anything
I don't know if there is a way to shutdown on low battery, but there is a suspend option setting in Settings > Power:
If you can't find it, try typing "suspend" on the settings window search bar as follows:
Sadly there is no option to suspend at specific battery level.
4 posts were split to a new topic: Setting Zorin OS to suspend when battery is low
