From like 7 months I installed zorin os for the first time but I encountered an error when I downloaded the 340 package and when I rebooted my PC it doesn't open
And still I downloaded zorin today and the same thing happened.
So is there any solution I tried alot before but none of them worked like download a stable version of kernel
And I remember downloading Nvidia packages but none of them worked.
That is now clear from your screenshot.
I assume you have selected the Nouveaux driver as the proprietary NVIDIA 340 does not work for you.
Please wait for someone who knows about NVIDIA drivers to see this and can help you.
ok some things of what we did from 11 months:My graphics card doesn t support kernel 5.15 i think because nvidia 340 is quite old(this is what storm said in the beggining)
i think nvidia-driver-440 didnt also work
i installed nvidia 390 but my laptop freezes
aravisian said this(between he did alot of things i didn t mention)But, you are still unable to boot you said. So this implies that the blacklist file was not the cause or the problem.
i tried to install stable kernel 5.4 but i can t boot
Once installed, boot into the 5.8 kernel using the Grub Menu - Advanced Options for Zorin
You can double check that you are on 5.8 with terminal command
uname -r
Then test the 340 driver.
The command I gave above includes the Linux-Modules-Extra package.
The apt search command was just in case you wanted to see what kernels are available through the repository.
(If the 5.8 works, I'd stick with it.)
