I installed Zorin Pro on my MacPro 2012, and have issues with keyboard working, so i want to try to give a try to Zorin Lite.
How do i do that?
Can i use the same booted USB, i think it included Lite, or how do i switch?
I would stay certain.
Download Zorin OS Lite from the emailed Download Link and create a Bootable USB.
Boot into the LiveUSB and **Test Zorin Lite out... See how things work a bit...
If you decide you'd like to continue testing in a full environment, Install by whatever option you most are comfortable with. You can overwrite Zorin OS completely - or choose to install Along Side...
@Gdaiva1 Ah, now we know you do have ZorinOS Pro. So also see this:
You have choice of Lite or Pro Lite.
working on it, will let you know how it goes, thank you
I re-installed Lite and there was an option for Machintosh keyboard, but still doesnt work, so im going to try Elementry next, they promote for mac users, so will see, if i can use my Mac then
, disapointed with Linux, and i paid for Zorin and Elementary, but oh well, hoping the Elementary will work
Thank you guys for your help!
Have you considered sending an email directly to the staff for tech support? I forgot exactly how to do that but I remember having that option with Z15 ultimate and I’m sure you have that option with Z16 pro.
It may be worth a shot.
I did, they said the same:try to change the layout, etc, which i already did before
OMG, on Elementary no Wi-Fi ...!?
My Linux journey...
OMG, i found out how to copy/paste!!!
it Control+C, Control+V.
Now, i need to figure out how to correct spelling and take a screenshot
