Installation Error Zorin Education
I was installing Zorin Os education and I've already installed windows 10,when I boot from usb after 2,3 second It says ;
Please someone help me.
Can you please check this thread?:
It's not installing,when I simply press key when BIOS say press any key to boot from USB after 2 3 second It says ; Kernel offset.
In that case:
In your BIOS, are you set to RAID or to AHCI?
What etcher did you use to burnt he bootable USB?
In BIOS I've set to RAID, and the etcher I was used was Rufus.
If using eMMC or nVME, you might try AHCI as a test.
