When I'm trying to install the installation goes normally until the very end right before it has you reboot when this error pops up. It doesn't list any broken packages with it though so I try rebooting and then it boots to BIOS and doesn't seem to register that theres an operating system of any sort on the drive. I've tried multiple ISO's including from different sources, and both the NVMe drive that I used and the flash drive worked to install a different OS right after I had tried with this. Any help anyone can give would be appreciated.
After I posted this I was able to find this post which seems like it may have the solution, I'm going to try when I have a moment and see how it works https://forum.zorin.com/t/installing-zorin-os-18-failed-dpkg-error/54477?u=tice4m
Yes, try it with the solutions mentioned there.
Recently (a few days ago) a new .iso Zorin 18 r1 was published. It should also solve some problems of the first version as dpkg errors.
