Depends on how long you can wait for. I'd wait for Zorin OS 16 LITE, but its up to you.
Yes you folks get my highest respect and admiration .... here I am dealing with just one train of thought while you people as support personnel are dealing with a great many facets all at the same time ....
All I can say is thank god you get paid well for all your time and effort ....
ZorinGroup pays us 5cents per Solution we rack up. I, for one, am saving up for a yacht.
Summary
ZorinGroup does not pay us any money, much less 5cents per solution.
WOW ... that is great as long as they don't bill us for it .... with all the responses you folks have made to me I'd be broke .... LOL
You haven't gotten the bill, yet? Watch your software-updater for it.
Yup and there will be the usual response from me .... "But honest sir I did put the check in the mail"
I will little focus on xfce. I will find some tutorials and put here some photos.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.ubuntupit.com/best-xfce-themes-for-linux/&ved=2ahUKEwjJ3cPC6ObzAhVnx4sKHYhlDYYQFnoECAQQBQ&usg=AOvVaw32AbXrezouLuM6LY1gbfCA
Here link
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.xfce-look.org/browse/cat/252/page/14/ord/latest/&ved=2ahUKEwihkNe46ebzAhVlkIsKHUwOCB4QFnoECDQQAQ&usg=AOvVaw2xWNRlESIH06Bs8XzzbgJu
Huh... several of mine are on that list. Though I have removed them, now.
Is there a way to move the taskbar to the bottom ???? ... I didn't see anything related to the taskbar
Sorry if i put something double @Aravisian but its help me find in this forum after switching many websides.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://itsfoss.com/customize-xfce/&ved=2ahUKEwj7tv3H6ubzAhUMvYsKHRjwA5IQFnoECB8QAQ&usg=AOvVaw0IRJfwjZ0QTkcjVnNRZRNe
Right Click the panel (taskbar) to change any setting you want.
In this case, right click, then slide over the Menu Arrow next to panel on the popover menu. Select panel preferences.
In the Pop Up window, uncheck the box for lock panel.
handles will appear at the end of the panel. Click the handle and drag the panel to where you want it to be. Once positioned, you can check the box for lock panel.
You can also position the panel in the middle and resize it to look like a Middle Dock.
What themes xfce are you prefered or liked? Have you got any idea od solutions?
Not right now with themes .... just trying to get my head around setting up the stock XFCE ... but thanks anyway maybe later
Your bill is: 1-billion dollars waaaaaa ha ha ha ha. ![]()
lol
Like I said YOUR check is in the mail .... but please don't rush out and buy that brand new bright red Lambo yet ... LOL
This is busting me up.
My Azenis theme is listed in this article.
The author states:
The title bar is quite modern and beautiful. The buttons have got a 3D effect on them.
Modern Ya see that?! MODERN
(Drops the mic)
Yes I went to the link to see that. I also like your Azenis theme, I always have. Its better geared to XFCE though, thats where it shines and works well. This would also be a good theme to go with, if someone didn't want your latest creation. Cause both are awesome you know.
I patched Azenis2021 to work with Gnome and CSD's.
OK that worked perfectly except that little group of icons that look like a tool bar in the middle of the screen at the bottom with the quick choices on it will not move up a bit when I pull the taskbar all the way to the bottom .... does it move ????
It sounds like your set up has two panels. Right click the one on the bottom and unlock it, then move it, the same way. You also can Delete an extra panel.
