Hello everyone,
I encountered an issue where my Intel b50 drivers (mesa) on Zorin 18.1 Pro wouldn't detect the GPU with a recent kernel update to 7.0.0-38-generic. I rolled back to 7.0.0-34-generic successfully using this post.
However, when I tried to set the grub menu to always select 7.0.0-34-generic on boot using this in my grub file /etc/default/grub
GRUB_DEFAULT=saved
GRUB_SAVEDEFAULT=true
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
Then I used sudo update-grub to save the configuration. The output of that command is the following:
Sourceing file '/etc/default/grub'
Generating grub configuration file ...
Found theme: /usr/share/grub/themes/zorin/theme.txt
Found linux image: /boot/vmlinuz-7.0.0-38-generic
Found initrd image: /boot/initrd.img-7.0.0-38-generic
Found linux image: /boot/vmlinuz-7.0.0-34-generic
Found initrd image: /boot/initrd.img-7.0.0-34-generic
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings...
done
The command appears to be working normally, but the system doesn't boot to 7.0.0-34-generic without manually selecting that specific kernel each time.
I'm considering deleting the files /boot/vmlinuz-7.0.0-38-generic and /boot/initrd.img-7.0.0-38-generic to just remove the kernel I don't want/need. If that's a safe option, how do I prevent it from downloading in the next update.
On the other hand, perhaps I made a typo in the grub file and I'm just not seeing it?
Regards, kilo
