Yes, it does. I suggest Reinstalling the package.
I linked an easy self installer to help with that.
I recommend using gdebi, but you can use the terminal if you prefer.
Awesome. I'll give this a try. Really appreciate the help. Did not know you could do a "re-install" which I guess is nice to know for when you see a symptom like this.
Log from install (via gdebi)
(Reading database ... 323087 files and directories currently installed.)
Preparing to unpack .../linux-modules-5.14.9-051409-generic_5.14.9-051409.202109300934_amd64.deb ...
Unpacking linux-modules-5.14.9-051409-generic (5.14.9-051409.202109300934) over (5.14.9-051409.202109300934) ...
Setting up linux-modules-5.14.9-051409-generic (5.14.9-051409.202109300934) ...
Processing triggers for linux-image-unsigned-5.14.9-051409-generic (5.14.9-051409.202109300934) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.14.9-051409-generic
W: Possible missing firmware /lib/firmware/i915/skl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/glk_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/cml_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/ehl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_huc_7.5.0.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_dmc_ver2_02.bin for module i915
/etc/kernel/postinst.d/zz-update-grub:
Sourcing file `/etc/default/grub'
Sourcing file `/etc/default/grub.d/init-select.cfg'
Generating grub configuration file ...
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34699: /usr/sbin/grub-probe
/dev/sda: open failed: No medium found
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34712: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34727: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34740: /usr/sbin/grub-probe
Found theme: /usr/share/grub/themes/zorin/theme.txt
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34831: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34849: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34867: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34889: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 34979: /usr/sbin/grub-probe
Found linux image: /boot/vmlinuz-5.14.9-051409-generic.signed
Found initrd image: /boot/initrd.img-5.14.9-051409-generic.signed
Found linux image: /boot/vmlinuz-5.12.0-051200-generic
Found initrd image: /boot/initrd.img-5.12.0-051200-generic
Found linux image: /boot/vmlinuz-5.11.0-41-generic
Found linux image: /boot/vmlinuz-5.11.0-38-generic
File descriptor 69 (pipe:[314005]) leaked on vgs invocation. Parent PID 35797: /usr/sbin/grub-probe
File descriptor 69 (pipe:[314005]) leaked on lvs invocation. Parent PID 36069: /bin/sh
Adding boot menu entry for UEFI Firmware Settings
done
You can follow this to get rid of the missing firmware warnings:
Following the link to the post in "Bad behavior..." Should be all you need for that.
I am sorry, scrolling between this post and the O.P., I cannot tell which is yuor /dev/sda/
Can you clarify which drive that is?
Once you are able to boot, we may need to check your global filter in /etc/lvm/lvm.conf
Did the re-install, and rebooted. Same symptom.
Here is output of my drives:
nvme0n1
├─nvme0n1p1 vfat 71F5-BEA3 505.8M 1% /boot/efi
├─nvme0n1p2 ext4 12ceaf52-1852-42f1-aeb3-8b114acc8ad4 354.9M 42% /boot
└─nvme0n1p3 crypto_LUKS 43a6282d-7a2d-48e0-802c-78371fc519ca
└─nvme0n1p3_crypt LVM2_member 9zRJUZ-ZIsE-tJCQ-YDFo-dYze-86Nh-hoo0tb
├─vgzorin-root ext4 0df273cb-51e9-4b37-8431-b44ba0a680e1 398.1G 7% /
└─vgzorin-swap_1 swap 35347cf8-8ba6-49b1-b45f-f1d276b64c97 [SWAP]
Time to grub a LAN cable?
Do you have only one nVME drive?
I am on a LAN cable as we speak:)
Yeppers.
I need to run to the store shortly... If you like, try @FrenchPress 's suggestion, Then we should check the above lvm conf file.
I think it is safer for OP to wait for you.
I do not have any NVMe on my system and I am not familiar with that at all.
Neither do I. @337harvey does...
It probably does not help that I appear semi-braindead today... You bunch really should be using Small Words.
You lost me (which is not so hard to do).
It is more of a Western Expression. When someone seems to be a bit distracted, we say to "use small words" because they will not understand "big words."
I will see if I can help OP to revert back to the supported kernel.
Can you open Synaptic and search for the keyword below?
linux-headers
Then sort the result to show the installed kernel.
Mine looks like this:
Done. Which specific kernel should I DL?
I need a screenshot like what I posted above.
The list of all installed kernels.
Do you see the kernel 5.11.0.41?
If so, you can select those for installation.
