Hey guys . So i wanted game mode but the command they provided on the forum does not work.
Second : when i use wine and play some old games which requires to change screen resolution to a smaller resolution. Game works fine but sometimes flickr ( light black ) and when i exit the game . The resolution does not change to the same old one .
Third in games like Minecraft there is a serious fps drop.
Specs : Intel i3 10th generation , 4 gb ram
256 gb SSD and fresh installed zorin os 16.2
Thank u
you should upgrade your ram
well I have i3 8th gen 12gb ram 512gb ssd
and facing the same problem
getting 40 fps in krunker.io
whereas in windows I get 60 fps stable
Well i tried zonrin os on my coding laptop with Intel i3 10th gen and 12 gb ram and zorin os core it happened the same like the games which give good fps on windows just gives nothing on zorin , i did in last year , some expectations are my old Sony laptop with is low end and games which windows gives low fps there zorin os lite gave me execptonly higher fps not one or two more but littlery 20 to 30 fps extra .
