Hi guys,
I am now officially using Zorin 16 as a main OS.
The photoshop need was the main reason why I couldn't leave windows sooner.
Then, I found photopea.com which is a free to use online photo editing software similar to PS and it also supports AI, pdf and even XD.
As most of you here are Linux supporters, you should know about photopea in case someone tells you that they can't leave Windows because of Adobe apps. That was me for example and as soon as I found it it was a done deal.
Anyways, Zorin is amazing. Almost everything runs smoothly. I am yet to figure out the Dropbox use but I see that it's possible.
I have the following needs and if you know if this is possible please share how or anything that can help me.
- I need a VM linux app to install Windows 10 as a VM just in case. I am a freelancer so you never know.
Preferably, I'd love to have an option to link to a windows application within that VM, on my Linux desktop.
For example, a PS windows app shortcut on linux desktop. When clicked it firsts boots up the windows VM and then immediately opens a PS program. I hope you get the picture. I don't know if this is possible or not.
So my question is.. what is a good VM linux app and which one could do what i suggested?
Zorin OS keeps asking me for these weird passwords for skype, google chromium and etc. Whenever I login to the system and start these apps, I am asked for some password. If I don't provide it, I am logged out of these apps.
How can I fix this? -
I installed Flameshot as a screenshot solution. However, on Windows I used to map a keyboard shortcut to my mouse button so that I can take a snip and shortcut faster. Flameshot doesn't appear to have a shortcut for their function. Can I manually make a key combination shortcut to run a program like that and configure my mouse for it?
Is there a way to increase my swap file size after the installation? Its just 2gb and after my first workday in ZorinOS I can tell that I will need more. In Windows I kept my paging file on 20gb.
That's all for now. Thank you in advance to whoever has any of these answers.
Zorin is amazing and this community is a very good place.
As soon as I get accostumed to the system, I will upgrade to Pro to support it!
There are pictures around the forum somewhere of that...
