Kernel 6.17 freeze on login after installing Nvidia 5060 laptop GPU. PLEASE 🥺 HELP!
Also just wanted to point out in "Authentication" all keys are deleted. Just in case that was questioned.
It's weird because it's software is installed for updating the hard drive but it's just not registering that it's installed internally. I have it selected on "Additional Drivers" 0 Using NVIDIA driver metapackage from nvidia-driver-580
Which also shows my work that I grabbed the package in terminal but it's just not clicking or when it does, it freezes on boot
ya... at this point i am stumped maybe get it back on the amd chip for now till @Aravisian appears....sorry man all im seeing is same stuff you posted yet it still isnt working
No, that's okay. Now I can't [sudo apt update] because the keys are deleted.
I do appreciate you trying to help.
Maybe I should just try booting ZorinOS with Nvidia install and see how that goes.
hey at this point what can it hurt....right
It just... Feels like I'm giving up! I hate that but at this point, I did all of the things and it's just booting software. I'll try to boot and see if that solves it
now ya know why i yanked my RTX 3050 out...lol
Bro I laughed way harder than I should have at that.
this is Zorin 18 core?
Correct
well your booting into 6.14 6.17 has cause alot of troubles
6.18.15-3-liquorix-amd64
what kernel im on
Yeah but if I boot into 17 it freezes. I downloaded from the site earlier and it flashed me 6.17
i installed the liquorix kernel when it was 6.18 .9 when it got to where i am i removed the repo to stay here as it loads 6.19 4 now thats to close to cutting edge and mine works awsome where it is
Oh dude it's getting the latest Nvidia update in boot. I think that's the issue was not booting in modern graphics
hopefully some with abit more knowledge then me can get it working the 5060 is a rather new vid cardmaynot even be supported in 6.14 or 6.17
So you lurk the Zorin forums to bring people to the liquorix side? :joy:
hmm possible possible
not really i just try to help i wanted to see if a higher kernel would help..and it did
they are working on 6.17 there is updates alot now so its getting better
So... About liquorix
there is a post in forum let me find the link to it
