Kernel 6.17 freeze on login after installing Nvidia 5060 laptop GPU. PLEASE 🥺 HELP!
unless it lets you reinstall the keys
Hold on, I didn't see I could restore keys
awsome
Yeah, it's not the same amount of keys and when I try to update it says the keys are missing so I'll try bootinging the flash in safe boot and see if that fixes the error but that means I can't get modern drive :sob:.
Step 1: uninstall
Step 2: question your life choices
Step 3: help : help not found
not sure if a sudo update-grub will be required
No but it makes sense why certain things aren't working correctly and I can't boot to 6.19
you have an awsome attitude most folks would be screaming by now and throwing stuff
this is just the way linux is..sometimes ..... its nice when it works...its just getting it there
Like I said, I love trouble shooting. This doesn't bother me. It's more like trying to solve a puzzle and learning along the way. Plus it helps I am a Christian. But you put me in front of someone who continues to deny facts instead of at least admitting they might be wrong about something and I lose patience. That or having to do dishes... I hate doing dishes but I do them by hand every other day
Exactly! The satisfaction of solving it! That's when you feel like you aren't as stupid as you constantly told yourself 5 minutes ago :joy:
well your in the right mind...most arnt.. if your willing to troubleshoot then linux is for you if your wanting plug and play this isnt what ya need
hey when i started at OS 16 my mouse didnt scroll got a better mouse then the nvidia troubles solved them... then upgraded to 17 then to 18 now i got rid of nvidia using amd 6600 xt and life is good now
Well, if I wanted to plug and play, I'd sell my morals and go crawling back to Windows. Good thing I'm not about to sell myself short :smiling_face_with_sunglasses:
well i was duel booting till 8 months ago thats when i wiped windows drive and did this for 2 weeks....didnt reinstall windows...lol
Yeah, I can't use HDMI but I know if I get the drive registered, it'll sync up. That's actually how I found out the rtx wasn't recognized by Zorin
well nvidia hasnt been real "friendly" with linux till just lately guess he sees the writing on wall amd drivers are built into the kernel
Windows 11 almost killed my old laptop. I put Zorin on and it worked like it did when I first bought it. So I know the hard work is worth the outcome for a higher end pc
ya linux dont have 120 to 190 processes running in background nor does it have all the spying either
Right, which is why you get more out of Linux than with windows and I'm willing to bet the components (if treated well outside the software end) lasts longer than on windows
heres what im running and its watercooled too
