Before I begin, I'd like to tell you I'm running ZorinOS 16 with persistence through a USB, which could likely be the cause of this.
Every time I have to use another keyboard language, I have to go into settings, remove the default three English variations and add my preferred language as a second option.
After rebooting, all of the keyboard settings reset, and I have to manually set them up again.
Does anyone have any idea whether this sounds like a problem with running the system from a pendrive or whether there's any way I could make the changes stick after restart?
Where are the keyboard settings stored exactly on Linux? Could I create a script that would auto-set the correct settings for me on system startup?
These are the settings I would like to change to for example:
I was not aware that USB persistence worked for Ubuntu 20.04/Zorin 16. Although some have said it does work if using Ventoy. @siko what USB creation software did you use?
I used Ventoy for this and made the persistence file straight from the 'Try Now system'. Then I think I saved the whole file on my SSD, booted to Windows SSD and transferred the persistence file back onto the USB stick.
Again, I don't remember the steps exactly anymore, but I could recreate them, if anyone needed help.
