Hey guys
complete newbie to Linux here
just installed Zorin OS 16 pro on my laptop on dual boot.
While installing i was able to have the display as an extension on my external monitor, post installation, it seems that i cant connect to the external monitor any more.
Can you move to the app menu and search for Software & Updates
launch the application, then navigate to the Additional Drivers tab.
It should search for drivers - once it has finished, ensure you have Nvidia 510 (Proprietary). Select that driver, then select Apply chnagesLog out and in after closing outSoftware & Updates` and test...
I really wonder why zorin has so much issues with nvidia drivers while pop os and other distors does not have this.
I see alot issues here with 515 driver while pop os has zero issues with that driver in the past 3 months. I use 525 driver now for almost 2 weeks with zero issues.
Maybe a idea that zorin should prehaps use the drivers from system76 ?
Every users experiences can vary. Aside from the initial 520 driver, I have had zero problems.
Sometimes, other users do.
But the Nvidia Drivers used in Zorin OS are the exact same drivers as used by POP_OS.
And the kernel loading is the same - both are also based on Ubuntu...
It may be that users on this forum are a bit more comfortable approaching with issues so we hear of it more readily.
Often, there are two graphics cards - the built in Intel graphics on the motherboard (Integrated) and the AMD or Nvidia inserted Graphics card (Dedicated.)
so the same cable was working fine, while i was installing Zorin OS.
I could see the installation happening on my external monitor,
Once the installation was done, it stopped working.
Is it ? Because pop os does not recommend installing the driver by hand duo different dependency or something like that.
I also still wonder how pop os or zorin os (or any other distro) implement those nvidia drivers on their system to get installed without getting into tty. When i install the nvidia driver by hand i need to blacklist the nouveau driver and then install the nvidia driver.
