jarkky
September 7, 2020, 4:13pm
1
Sometimes, with Teams application, the microphone does not work.
Sep 7 22:46:33 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 22:11:24 spice-vdagent: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
Sep 7 22:11:21 pulseaudio: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
Sep 7 22:11:20 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 22:11:20 pulseaudio: [pulseaudio] alsa-ucm.c: sof-hda-dsp UCM not found: map sof-hda-dsp -> sof-skl_hda_card
Sep 7 22:10:20 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 21:10:40 spice-vdagent: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
Sep 7 21:10:10 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 20:57:57 kernel: ACPI Error: Aborting method _SB.WMTF.WMTF due to previous error (AE_AML_PACKAGE_LIMIT) (20190816/psparse-531)
Sep 7 20:57:16 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 20:56:52 spice-vdagent: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
Sep 7 20:56:50 pulseaudio: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
Sep 7 20:56:50 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 20:56:50 pulseaudio: [pulseaudio] alsa-ucm.c: sof-hda-dsp UCM not found: map sof-hda-dsp -> sof-skl_hda_card
Sep 7 20:56:35 systemd: Failed to start LSB: Folding@home Client.
Sep 7 20:56:32 spice-vdagent: Cannot access vdagent virtio channel /dev/virtio-ports/com.redhat.spice.0
Sep 7 20:56:30 pulseaudio: [pulseaudio] main.c: Failed to acquire autospawn lock
Sep 7 20:56:30 kernel: sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
Sep 7 20:56:29 kernel: lis3lv02d: unknown sensor type 0x0
Sep 7 20:56:29 kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-221)
Would this proffer a possible solution?
opened 12:23PM - 12 Jan 20 UTC
closed 02:32PM - 29 Jan 20 UTC
bug
P1
CML
**Describe the bug**
On my Lenovo Yoga C740 with a Comet Lake CPU (i7-10510U), … the dual-microphone array does not work. Speakers are working. In GNOME settings, "Input device" shows "Multichannel input (sof-hda-dsp)", but the input monitor bar (below the input selection combo box) does not register any input noise and Audacity records only silence.
I have "dmic0" and "dmic1" in alsamixer, though.
**To Reproduce**
I'm on Ubuntu 19.10. In order to have proper SOF support, I installed [mainline kernel 5.5-rc5](https://kernel.ubuntu.com/~kernel-ppa/mainline/). I stole the firmware files from the [latest Fedora package](https://koji.fedoraproject.org/koji/buildinfo?buildID=1426494).
**Reproduction Rate**
100%
**Expected behavior**
Microphone input to be recorded in Audacity.
**Impact**
showstopper if microphone is needed (not for me, though)
**Environment**
Ubuntu 19.10 with mainline kernel 5.5-rc5, alsa-firmware-1.2.1-4 borrowed from Fedora 31
**Screenshots or console output**
This is my `dmesg | grep audio`:
[ 21.174697] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 21.174946] sof-audio-pci 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 21.174960] sof-audio-pci 0000:00:1f.3: enabling device (0000 -> 0002)
[ 21.175292] sof-audio-pci 0000:00:1f.3: warning: No matching ASoC machine driver found
[ 21.175301] sof-audio-pci 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 21.175469] sof-audio-pci 0000:00:1f.3: use msi interrupt mode
[ 21.175726] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 21.185616] sof-audio-pci 0000:00:1f.3: hda codecs found, mask 5
[ 21.185619] sof-audio-pci 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 21.542017] sof-audio-pci 0000:00:1f.3: unexpected ipc interrupt raised!
[ 21.542020] sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
[ 21.642253] sof-audio-pci 0000:00:1f.3: Firmware info: version 1:1:0-fcf6c
[ 21.642256] sof-audio-pci 0000:00:1f.3: Firmware: ABI 3:11:0 Kernel ABI 3:11:0
[ 21.642490] sof-audio-pci 0000:00:1f.3: firmware boot complete
[ 21.880019] sof-audio-pci 0000:00:1f.3: Topology: ABI 3:11:0 Kernel ABI 3:11:0
[ 21.880027] sof-audio-pci 0000:00:1f.3: warning: widget type 7 name iDisp3 Tx not handled
[ 21.881436] sof-audio-pci 0000:00:1f.3: warning: widget type 0 name codec0_in not handled
[ 21.881439] sof-audio-pci 0000:00:1f.3: warning: widget type 7 name iDisp2 Tx not handled
[ 21.882280] sof-audio-pci 0000:00:1f.3: warning: widget type 0 name codec1_in not handled
[ 21.882282] sof-audio-pci 0000:00:1f.3: warning: widget type 7 name iDisp1 Tx not handled
[ 21.883293] sof-audio-pci 0000:00:1f.3: warning: widget type 1 name codec0_out not handled
[ 21.883296] sof-audio-pci 0000:00:1f.3: warning: widget type 7 name Analog CPU Playback not handled
[ 21.884120] sof-audio-pci 0000:00:1f.3: warning: widget type 1 name codec1_out not handled
[ 21.884123] sof-audio-pci 0000:00:1f.3: warning: widget type 7 name Digital CPU Playback not handled
[ 21.884125] sof-audio-pci 0000:00:1f.3: warning: widget type 0 name codec2_in not handled
[ 21.884127] sof-audio-pci 0000:00:1f.3: warning: widget type 7 name Alt Analog CPU Playback not handled
[ 21.884129] sof-audio-pci 0000:00:1f.3: warning: widget type 1 name codec2_out not handled
[ 21.884131] sof-audio-pci 0000:00:1f.3: warning: widget type 0 name Analog CPU Capture not handled
[ 21.884854] sof-audio-pci 0000:00:1f.3: warning: widget type 1 name iDisp1_out not handled
[ 21.884856] sof-audio-pci 0000:00:1f.3: warning: widget type 0 name Digital CPU Capture not handled
[ 21.885585] sof-audio-pci 0000:00:1f.3: warning: widget type 1 name iDisp2_out not handled
[ 21.885588] sof-audio-pci 0000:00:1f.3: warning: widget type 0 name Alt Analog CPU Capture not handled
[ 21.886324] sof-audio-pci 0000:00:1f.3: warning: widget type 1 name iDisp3_out not handled
[ 21.893543] sof-audio-pci 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[ 21.912348] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC285: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 21.912350] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 21.912352] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 21.912353] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 21.912354] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 21.912356] snd_hda_codec_realtek ehdaudio0D0: Mic=0x19
[ 21.959138] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[ 21.959145] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[ 46.131032] sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
[ 46.224672] sof-audio-pci 0000:00:1f.3: firmware boot complete
[ 62.963068] sof-audio-pci 0000:00:1f.3: error: no reply expected, received 0x0
[ 63.062240] sof-audio-pci 0000:00:1f.3: firmware boot complete
I'd like to help to make this work. Let me know if I can provide any further info.
Other forum members having different issues have had them resolved by updating to the latest 5.5 kernel.
jarkky
September 8, 2020, 5:41am
3
I installed Fedora32 and it seemed to work and is visible in the menus:
In case of ZorinOS the Input/Output device selection seem fail somehow… I hope it get fixed ASAP.
Just done a search on kernel used by Fedora 32 and it is up to 5.8.6 already - it might be worth seeing if updating to 5.5 as I suggested earlier might resolve this issue - remember the kernel has drivers for hardware embedded in the kernel - Zorin provides the ‘skin’ if you like - in much the same way Fedora provides the ‘skin’ for the kernel it uses. I know I am over-simplifying this but just trying to put it in to simple terms.
jarkky
September 9, 2020, 4:33am
5
So, I hope to know if later kernel is available. It could be kernel version related.
Yes, I agree with your opinion and I also have an old laptop and now I want to start my Youtube channel so I was searching for the Best Video Editor Software For Low-End PC so that I can do video editing properly in my old laptop and while searching for this I landed on this website and I was glad to visit here as I get some extra knowledge and I also shared this website with my friends so that they can also get some extra knowledge.
