Hi everyone! I'm trying to install Zorin OS 18 Core, but the boot fail before installation. This is the error message: KERNEL PANIC! Please reboot your computer. VFS: Unable to mount root fs on unknown block(0,0)
Can someone help me?
System:
Intel Core i7-3770 CPU 3.40GHZ x 4
Memory 15.1 GB
Hard Drive 1012.2 GB
Graphic board Intel IviBridge GT2 HD Graphics 4000
- Did You checked the Checksum of the ISO?
- Did You tried it with donwloading the ISO again?
- What Tool did You use to create the bootable USB Stick with Zorin on it?
- Is Your BIOS in UEFI or Legacy Mode?
- Are Secure Boot and Fast Boot in BIOS disabled?
- Is Windows still installed? If yes: Is Fast Start-Up in Windows disabled?
Basic pre-installation advice can be read here: Before you install
