Lock Screen crash session in Wayland
My session crashes everytime I lock the session. I use wayland Zorin 18 core. It's always updated. When I lock the session I get a normal login. Once I login It takes a few secondes but I hear the sound click just like I would when login a new session but instead it transfer to my second screen and gives me another login that seems default. Once I login again, I have a new session and all application are closed. If I leave the PC open not even the screen saver kicks in. Any idea? I have a i7, Prime Mother board, GTX 5070. Out of ideas. Thx
It sounds like upon Wake, the GPU is not being initialized properly. So the desktop crashes.
This, sadly, is a recurring Gnome issue...
Try using Xorg, i had the same issue and using Xorg fixed it.
See, this morning is was fine. Weird... But I might switch to Xorg as before you might be right. Hopefully they fix it in the future. Wayland has been great for me so far.
