Hi All!
Is installed ZorinOS 16 yesterday, so far good vibes. But, I have a Yoga 530, so I have to use tlp to keep my battery alive. I managed to set it up and the threshold settings seem to be working fine: my battery is not getting charged at e.g. 70%, while conservation is enabled, as it is using 60% as a threshold.
However, I have a problem. As far as I boot the system in AC mode, charger plugged in, Bluetooth is working, my USB mouse is working, but when I unplug the charger, tlp goes into "battery" mode and Bluetooth and USB ports are gone dead.
Does anybody had the same experience or any kind of solution you might have found? Thanks!
