Headphone : Sony MDR ZX220BT
In windows the sound output was fine
but in Zorin even if I keep the volume at max ..it's still low .
I have already select the over amplication option ..to go beyond 100
But it get distorted in some songs/videos
I am using the defualt drivers
Is there anything I can do ?
I am wondering if it is a sound problem or a Bluetooth problem.
Anyhow lets see what @meeseeks098 can see in his Alsamixer display.
Open terminal Ctrl=Alt+T
then type alsamixer
Please post a screenshot.
Whilst in Alsamixer:
1 Check your soundcard is showing correctly, else hit [F6] to list and change it.
2 Check that none of your outputs are showing Muted or output levels are low.
3 Check Automute setting. Try disabled and see if that helps.
4 Try changing Loopback setting and see if that helps.
On the Bluetooth side, @FrenchPress is better qualified than me. But a common reccommendation on here is to install Blueman as your bluetooth device manager.
If you think the problem is solved, please mark the thread as solved
It will help the future visitors to the forum to find the solution they are looking for.
Thank you for choosing Zorin OS 16 and for supporting the dev's by buying PRO, you are positively stellar!
I do believe Zaba's post was the solution though. But at any rate, I am glad the issue is fixed. I assume your using USB headphones? I've been hearing some really good things about the USB headphones, because they are digital, and thus quality of sound transmission.
In the past is used to be you need a DAC to get any good sound at all from a computer lol. Anyways, please continue to enjoy Zorin OS 16.
Thats strange, guess not all bluetooth headphones/headsets come with wired 3.5mm ports. I have a pair of Cowin E7 Pro's that come with a wired port on them, which I have used many of times already. Here's mine!
