I installed a theme and the highlight color in the main menu makes it so i can't see the program name easily. I was looking around the gnome-shell.css file to change it but I'm unsure what this part is called to alter it. Screenshot attached.
What Theme is this? Maybe it would be good to contact the Theme Developer about this, too.
I just realized there are bigger issues than just that with the shell of the theme I'm using. I think I will just look for a different one to use.
When it should be am Issue where You have in the Shell blue Color instead of the Theme Color, this is a known Issue. I have posted it by myself a While ago:
Zorin OS 17 includes LibAdwaita, in addition to a blend of GTK3 and GTK4 applications.
Gnome continues its anti-user theme practices.
They should take LibAdapta from the Mint Project.
