Minimized App icons not showing in Panel (solution Zorin LITE)
Hi all, after using Zorin OS 16 for months without showing the minimized applications on desktop taskbar, I found the solution at an old xfce forum.
https://forum.xfce.org/viewtopic.php?id=8932
Is quite simples, just reinstall a xfce plugin to panel by clicking on task bar panel and selecting menu Panel -> Add New items and search for "Windows Buttons".
Voilá....your application minimized are there.
Regards
There's an original post here about the same issue.
Yep...mine was too, but after I added Windows Buttons again, everything started working again (solution here)
[]'s
