It's me again. I'm having another issue with Zorin 16 OS which appeared out of the blue and like 4-5 weeks ago without me changing anything.
I have 3 monitors and I have set in power settings, that they'll turn off after 8 minutes of inactivity. However, as I said, for the past 4-5 weeks they do not turn off anymore. At all. It can be 30 minutes, 12 hours or 9 minutes afk, the monitors are all still turned on.
How would you approach this problem? Is there anything I can do?
A small addition to that is, that the lock screen doesn't appear either, even though I enabled it in order to confirm waking up the computer with a password, which simply doesn't show up
The screensaver is usually what handles the Lock Screen and Monitor power down, not the power settings.
And no, you should not run that command. I was checking if you had because it would disable the power manager or screensaver from turning off the monitors or enabling the screensaver lockscreen.
I use Zorin LIte... Which is XFCE. Not sure about Gnome (Core).
In your Zorin Settings > Power
What is displayed under
"Blank Screen"
"Automatic Suspend"
Oh, I'm sorry! If it's not too much to ask for, would you mind sending me a screenshot of this? I still cannot find it (Not sure how these settings are called in German)
I'm not sure what the German equivalent to "Blank screen" would be, but I suppose it's the time until the monitors shut down? This would be 1 minute. Automaitc Suspend is turned off now, but tried it with both, turned on and turned off which both didn't turn the monitors off
Tried you settings, mine worked the screen went blank (black that is) but I'm using just 1 monitor.
Are you sure that you have not installed any extension(s) within the 4-5 week period, that are mouse or screen related and which could have override the settings?
Mhhh well I installed imsettings to alter the mouse wheel speed on Zorin from a guide I found here. But I did this right when I installed Zorin in the first place like 3 months ago. But it could definitely be that I installed something like that but I'm not aware of Is there not a way to check this?
The IMWheel package should not effect this... Or... hmmm... actually it is possible. I think you would have noticed it pretty quick.
Have you checked the Settings app from the Zorin Menu? Move to the Power tab on the left pane.
If you do not see it, check the Back Button on the very top left... The Settings remains on the last opened tab after closed.
Yeah, I checked the settings app and found the power option, but no combination of those settings bring the monitors to turn off, sadly.
I did fumble around back then with the mouse's cursor speed settings around that time I think But I'm not sure at all if I could even recreate what I did there haha
Followed some guides that would alter the speed of the mouse cursor, let me see if I can find it
