Move notification location to the side of Notification Center
Since notifications are shown on the date menu of the panel (Notification Center), I believe new notifications also should be shown on the right side of the panel on Mac Layout.
I created this issue (Show notifications on the right side of the panel on Mac Layout) and solved my problem with Notification Banner Reloaded - GNOME Shell Extensions extension. I was told that to feature request I need to create an issue on "Feedback Category". I believe this feature should be natively on ZorinOS. (Just like Mac shows notifications on the right side)
Note : Since Zorin OS doesn't have the option to show panel (upper taskbar) on the second screen, I use Multi Monitors Add-On - GNOME Shell Extensions. I believe this should be on the Zorin Appearance instead of depending on an extension (@AZorin or @zorink). Thank you.
