Hi There Zorin users. I'm new to Zorin and I have little difficulties steering my way through problems I've encountered. My desktop's settings:icons,themes,wallpaper disappeared this morning and I'm really at loss of what to do. I can't right click on my desktop page and I can't do anything else. I would be happy if I could get suggestions on what to do.
Application Finder... that is a Zorin OS Lite or Zorin Pro Lite feature.
Ok. The above instructions were for the Zorin Core (Gnome) or Zorin Pro (Gnome) Editions of Zorin OS. That tip will not work on Lite.
On Lite, please tap ctrl+alt+F3 to enter TTY. Note your Memory How TO Exit TTY - it is ctrl+alt+F7
Enter TTY and run
Using x86 Intel for graphics... Ok, that was not a solution, but was informative.
Can you use the TTY again...
And this time run:
sudo nano /etc/default/grub
arrow key down to the line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" and add the nomodeset parameter.
It should look exactly like: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
Tap ctrl+x to exit, then the y key to say Yes to save, then the enter key to save the current configuration.
Next you must run
I've done everything you said to Sir. I don't understand what you meant by the rebooting though......does it mean I have to go to the advanced options for zorin before rebooting?
I'm done with the reboot sir,and my laptop's graphics and display settings have totally changed. Can I undo the nomodeset stuff?. will it affect anything if I undo it?
I am looking over your images... and it appears, superficially at least, that the drivers are working.
But the appearance is off. Usually sizing and poor appearance come down to graphics.
But not always.
Have you uninstalled any software or installed any software prior to the change in your desktop appearance?
Have you run sudo apt autoremove prior to the change?
You might try
mv ~/.config ~/.config-bk
Log out and in. If no change, run
rm -rf ~/.config && mv ~/.config-bk ~/config
What the above does is backup your home config directory and then set it all to default settings to see if that purges any bad configurations. If it does not work, the second command restores the backup.
If you are able to launch and run terminal, you can use terminal.
I had the impression that your desktop was non-functional, Which is why I suggested TTY.
