Fedora Spins are a bunch of less resource-hungry and more lighter versions of Fedora.
No problem ![]()
Okay, this is the first time I am seeing in my life that an os forms promote to another os by seeing the user needs.
You people are great. You have not been thinking about selling your product and trying to help me.
Thank you very much.
Hello AdarshMeher, I see that everything went alright for you?
Yes sir. Everything is going right. Thank you.
You are most welcome my friend ![]()
Now I am going to install fedora.
Bye
After installing Fedora, you can tell me your experience
, based on which I can recommend you whether to switch or not
Please make a note of the solutions you have used here, in case you need them again on your Fedora build, such as speeding up boot.
You also can apply Zorin themes on Fedora if you liked the appearance of Zorin.
Yes, I will definitely tell you about my experience.
Now I am on a trip so I will return after 3 days. I will tell you about my experience after 3 days.
Sure, don't skip the tour of Fedora after installing it
, as it summarises its main features.
Okay, I will remember that.
Thank you for your suggestion.
Enjoy your trip. See you after 3 days
Thank you sir, bye
Bye
, stay safe
You can also watch this video to know in-depth about Fedora 35.
And this for knowing what things to do after installing Fedora 35.
Maybe you should replace that drive for a ssd in the future ? ssd's can give you better boot speeds as well.
Thank you very much, sir.
Sorry, sir, i can't able to reply at that time.
Yes, I am planning to do that in future.
No problem, is it installed now?
