Nala as package installer
I've tried it on Debian 13 (there it is available) and it really makes the Overview better in my Opinion. Maybe not as amuch as witl nala, but better that before.
Me neither.
Do I open Nautilis in the Terminal?
I'm just going to restart this laptop. I've been getting this weird display issue... all the text looks poor quality, grainy and difficult to read small text in particular. It affects image quality too. It's random though and a reboot usually fixes it. BRB
Your terminal output says that you had this file.
You enter the command in terminal and then wait until nautilus will be opened.
These folders/files are not in the home folder, but in root directory. When you open nautilus as root, you are in root directory at start of nautilus. Then click on etc>apt>sources.list.d
and then you can see the file nala-sources.list
But is is named in Your multiple configuration Issue:
W: Target Packages (restricted/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list.d/nala-sources.list:3
All I can tell you is that when I typed it into the Terminal it said doesn't exist. I really have no idea.
Can you please post the screenshot of the terminal output?
Do you use another file manager than the default file manager nautilus, e.g. nemo?
Don't use sudo at the beginning of the command, only nautilus admin:/
Hi, no I don't use anything else. I've installed Nala but nothing else different, except Xorg, rather than Wayland.
It takes me a while to read and try to understand, and then perform the action. Please just give me a moment :folded_hands:
Take your time! There's no rush! If it works, you don't need to take a screenshot.
It's best not to search for the file yourself using the terminal (I personally find this more difficult), but rather after the file manager has opened.
sudo: nala: command not found
Is nala still installed on your system or do you have removed the app?
I think I've removed it. I just: sudo apt upgrade and it suggested I run sudo apt auto remove unneeded files. I'm waiting for it to finish. If I've broken the system I'll just use Timeshift to roll back, or do a fresh install.
trinket@trinket-HP-Pavilion-TS-15-Notebook-PC:~$ sudo apt upgrade
Reading package lists... Done
Calculating upgrade... Done
black fonts-font-awesome libjs-bootstrap4 libjs-jquery-hotkeys
libjs-jquery-isonscreen libjs-jquery-metadata libjs-jquery-tablesorter
libjs-jquery-throttle-debounce libjs-lunr libjs-popper.js libjs-sizzle
mkdocs node-jquery pyflakes3 python-babel-localedata python3-anyio
python3-attr python3-babel python3-bs4 python3-charset-normalizer
python3-cov-core python3-coverage python3-execnet python3-flake8 python3-h11
python3-html5lib python3-httpcore python3-httpx python3-iniconfig
python3-isort python3-jinja2 python3-livereload python3-lxml
python3-markdown python3-mccabe python3-mypy python3-mypy-extensions
python3-nose2 python3-packaging python3-pathspec python3-platformdirs
python3-pluggy python3-py python3-pycodestyle python3-pyflakes
python3-pyinotify python3-pytest python3-pytest-cov python3-pytest-forked
python3-pytest-sugar python3-pytest-xdist python3-rfc3986
python3-shellingham python3-sniffio python3-socksio python3-soupsieve
python3-termcolor python3-toml python3-tomli python3-tornado
python3-typed-ast python3-typer python3-webencodings sphinx-rtd-theme-common
The following packages have been kept back:
libnss-systemd libpam-systemd libsystemd0 libsystemd0:i386 libudev1 systemd
systemd-oomd systemd-sysv systemd-timesyncd udev
0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
trinket@trinket-HP-Pavilion-TS-15-Notebook-PC:~$ sudo apt autoremove
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 64 to remove and 10 not upgraded.
After this operation, 116 MB disk space will be freed.
(Reading database ... 277434 files and directories currently installed.)
Removing python3-typer (0.4.0-1) ...
Removing black (21.12b0-1) ...
Removing mkdocs (1.1.2+dfsg-2ubuntu1) ...
Removing sphinx-rtd-theme-common (1.0.0+dfsg-1) ...
Removing fonts-font-awesome (5.0.10+really4.7.0~dfsg-4.1) ...
Removing libjs-bootstrap4 (4.6.0+dfsg1-4) ...
Removing python3-pytest-cov (3.0.0-1) ...
Removing libjs-jquery-hotkeys (0~20130707+git2d51e3a9+dfsg-2ubuntu1) ...
Removing libjs-jquery-isonscreen (1.2.0-1.1) ...
Removing libjs-jquery-tablesorter (1:2.31.3+dfsg1-3) ...
Removing libjs-jquery-metadata (12-3) ...
Removing libjs-jquery-throttle-debounce (1.1+dfsg.1-2) ...
Removing libjs-lunr (2.3.9~dfsg-1) ...
Removing libjs-popper.js (1.16.1+ds-5) ...
Removing libjs-sizzle (2.3.6+ds+~2.3.3-1) ...
Removing node-jquery (3.6.0+dfsg+~3.5.13-1) ...
Removing pyflakes3 (2.4.0-2) ...
Removing python3-jinja2 (3.0.3-1ubuntu0.4) ...
Removing python3-babel (2.8.0+dfsg.1-7) ...
Removing python-babel-localedata (2.8.0+dfsg.1-7) ...
Removing python3-httpx (0.22.0-1) ...
Removing python3-httpcore (0.14.5-1) ...
Removing python3-anyio (3.5.0-3ubuntu2) ...
Removing python3-pytest-xdist (2.5.0-1) ...
Removing python3-pytest-sugar (0.9.4-1ubuntu1) ...
Removing python3-bs4 (4.10.0-2) ...
Removing python3-charset-normalizer (2.0.6-2) ...
Removing python3-cov-core (1.15.0-3build1) ...
Removing python3-nose2 (0.9.2-1) ...
Removing python3-coverage (6.2+dfsg1-2build1) ...
Removing python3-execnet (1.9.0-1) ...
Removing python3-flake8 (4.0.1-2) ...
Removing python3-h11 (0.13.0-1) ...
Removing python3-html5lib (1.1-3) ...
Removing python3-isort (5.6.4-1) ...
Progress: [ 81%] [###############################################...........]
Removing python3-lxml:amd64 (4.8.0-1build1) ...
Removing python3-markdown (3.3.6-1) ...
Removing python3-mccabe (0.6.1-3) ...
Removing python3-mypy (0.942-1ubuntu1) ...
Removing python3-mypy-extensions (0.4.3-2) ...
Removing python3-pathspec (0.9.0-1) ...
Removing python3-platformdirs (2.5.1-1) ...
Removing python3-pytest-forked (1.4.0-1) ...
Removing python3-pycodestyle (2.8.0-2) ...
Removing python3-pyflakes (2.4.0-2) ...
Removing python3-pyinotify (0.9.6-1.3) ...
Removing python3-rfc3986 (1.5.0-2) ...
Removing python3-shellingham (1.4.0-1) ...
Removing python3-sniffio (1.2.0-1) ...
Removing python3-socksio (1.0.0-2~bpo22.04.1) ...
Removing python3-soupsieve (2.3.1-1) ...
Removing python3-termcolor (1.1.0-3) ...
Removing python3-tomli (1.2.2-2) ...############################............]
Removing python3-tornado (6.1.0-3build1) ...
Removing python3-typed-ast (1.4.3-1build1) ...
Removing python3-webencodings (0.5.1-4) ...
Removing python3-pytest (6.2.5-1ubuntu2) ...
Removing python3-attr (21.2.0-1) ...
Removing python3-iniconfig (1.1.1-2) ...
Removing python3-packaging (21.3-1) ...
Removing python3-pluggy (0.13.0-7.1) ...
Removing python3-py (1.10.0-1) ...
Removing python3-toml (0.10.2-1) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for fontconfig (2.13.1-4.2ubuntu5) ...
Removing the app is of course also possible. You had always raved about Nala, so I thought you still had it on the system and wanted to keep it.
This explains why you can no longer find the file.
The apt package manager is no longer reporting any warnings, so everything seems to be fine again.
Yes, you're right, I liked using Nala a lot, but when things like this happen and I don't understand how or why, I think it's better for me to just remove it and stick to something simple. Thank you @Forpli, @Aravisian and @Ponce-De-Leon for your help and patience.
I rebooted and re-ran the update and upgrade commands with this output. I think everything looks good now:
rinket@trinket-HP-Pavilion-TS-15-Notebook-PC:~$ sudo apt update && sudo apt upgrade
[sudo] password for trinket:
Hit:1 Index of /ubuntu jammy InRelease
Hit:2 Index of /ubuntu/ jammy-updates InRelease
Hit:3 Index of /ubuntu/ jammy-backports InRelease
Hit:4 https://brave-browser-apt-release.s3.brave.com stable InRelease
Hit:5 Index of /ubuntu jammy-security InRelease
Hit:6 https://packages.mozilla.org/apt mozilla InRelease
Hit:7 Index of /zorinos/apps/ubuntu jammy InRelease
Hit:8 Index of /zorinos/drivers/ubuntu jammy InRelease
Hit:9 Index of /zorinos/patches/ubuntu jammy InRelease
Hit:10 Index of /zorinos/stable/ubuntu jammy InRelease
Hit:11 Index of /stable/ jammy InRelease
Hit:12 Index of /patches/ jammy InRelease
Hit:13 Index of /apps/ jammy InRelease
Hit:14 Index of /drivers/ jammy InRelease
11 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following packages will be upgraded:
wireless-regdb
1 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
Need to get 10,1 kB of archives.
After this operation, 2 048 B of additional disk space will be used.
Get:1 Index of /ubuntu jammy-security/main amd64 wireless-regdb all 2025.07.10-0ubuntu1~22.04.1 [10,1 kB]
Fetched 10,1 kB in 0s (53,3 kB/s)
(Reading database ... 272609 files and directories currently installed.)
Preparing to unpack .../wireless-regdb_2025.07.10-0ubuntu1~22.04.1_all.deb ...
Unpacking wireless-regdb (2025.07.10-0ubuntu1~22.04.1) over (2024.10.07-0ubuntu1
~22.04.1) ...
Setting up wireless-regdb (2025.07.10-0ubuntu1~22.04.1) ...
Yes, everything looks fine now.
I'm not sure yet whether I'll continue using the programme nala. It's a bit unpredictable...I'm not entirely convinced yet, even though I like the look of the terminal output – but a good look isn't everything :wink:
I have decided to remove Nala. That uncertainty was not something I wish to try to untangle at a later date.
I like it, but it is not so different from APT to me to make the cost to benefit ratio turn in its favor.
I do like the latest APT changes, as well. I may test those on a test rig by using @littlekun's link to access the Unstable Repo:
Thanks Aravisian
Share us your testing experience when you done.
And there is a Stable repo as well, if this helps:
