Nautilus extension Dual Panel
hello, i'm a real newby on linux. i followed your instructions to install nautilus extension, but when i run "cp dual-panel.py ~/.local/share/nautilus-python/extensions/", i get : cp: impossible d'évaluer 'dual-panel.py': Aucun fichier ou dossier de ce nom". I do understand terminal doesn't know what to copy, but i don't know what to do.
You can do that graphically. Put the Script on Your Desktop. Then open Nautilus and press ctrl+h to show hidden Files. There go to .local>share and in this share Folder create a nautilus-python Folder. Then go in this Folder and create there a Folder called extensions and in this Folder You can put the Script from Your Desktop with the Mouse.
thanks a lot. every thing works perfectly.
