Nautilus (file manager) in Zorin 18 randomly stuck and thumbnails problem
For those who encounter a problem with Nautilus freezing during launch or use
Remove folder color
sudo apt remove folder-color
for now it seem working fine, if you can test and tell me if it work for you it could be great
A little trick if you have some thumbnails problem with SVG and PNG ( thumbnails have no background)
Clear thubmails cache:
rm -rf ~/.cache/thumbnails/*
Open your terminal and create/edit your profile's CSS file (if it doesn't already exist):
nano ~/.config/gtk-4.0/gtk.css
Copy and paste these lines inside:
.nautilus-window.view .thumbnail {
background: none;
box-shadow: none;
Save (Ctrl+O, Enter) and exit (Ctrl+X).
Restart Nautilus to see the change:
nautilus -q
I tested your method with removing the folder-color on my Zorin 18 live system two days and nautilus didn't hang since then :grinning_face:. I will continue testing it next week. Thank you for the tip!
My pleasure :wink:
@AZorin Thank you for the patch you deployed hours ago for this problem
What patch was deployed? I still had this problem today, and uninstalled folder-color. It seems now it no longer freezes.
But I was curious about the patch.
they build a patch in January for the folder-color problem
I did not receive anything of the sorts via updates, and as mentioned I still had the problem at that time. I fixed it via uninstalling folder-color.
removing the old folder-color was the good thing to do, if you want this functionality back, you can try the corrected extension I made, take a look at this
Thanks!
I just upgraded from 17.3 Pro to 18.1 Pro and Nautilus wouldn't open.
I removed folder-color and now it's started working.
That's interesting. I thought Zorin team already fixed this on 18.0
they don't if you upgrade, only fresh install is fixed
