agust
July 7, 2024, 3:45pm
1
Hey guys! Can you suggest some of your favorite customization tools for live wallpapers, widgets, and other stuff.
Storm
July 7, 2024, 3:47pm
2
Check out Gnome Extension site for stuff
Other than that you can use Hidamari for live wallpaper.
Also check:
[Effects Extension in Gnome]
You're looking for some fancy things for Gnome? Look no further.
jelly Mode
The easiest one to enable is Jelly Mode which comes default with Zorin OS. Simple go to Zorin Appearance --> Interface --> JellyMode
Magic/Fire Mode
First ensure that you have the tool to use extra extensions on Gnome. Open the terminal;
sudo apt install gnome-shell-extension-prefs
Next go to: Burn My Windows - GNOME Shell Extensions
and enable Burn My Windows extension. Mak…
Hidamari, with the animated wallpaper, left my desktop unusable. However, my hardware is very modest and weighed a lot
(I3-2120, 8Gb)
For Gnome Extensions I can recommend the Extension Manager (downloadable in the Gnome Software Store). You can manage Your Gnome Extensions and install them from this Program.
To find new Themes and Icons the Website Gnome-look.org is a good Adress.
I tried Hidamari on my Machine (Ryzen 3200G, 2GB for internal Graphic and 14GB RAM) and it works good. Yes, it needs more Ressources. That is normal.
agust
July 7, 2024, 4:55pm
9
How do I install the themes BTW, Is there any tutorial?
It kept giving me lag and freezes. AMD's integrated video doesn't compare to Intel's. HD graphics is very weak. I researched and your processor is much better than a 2nd generation I3.
Storm
July 7, 2024, 5:43pm
11
Here is a Link to a Guide for the Themes:
Download a third-party GTK, Gnome Shell, or XFWM theme. You can find many community-created desktop themes on Pling.com
Launch the Files app and open the "Downloads" folder
Right-click on the downloaded theme file and select "Extract Here"[extract-desktop]
Select the newly-extracted folder, right-click on it and select "Copy". Please make sure that there is a file named "index.theme" directly inside this folder.
Return to your Home folder in the Files app.
Open the app menu to enable the "Sho…
And here is a Link to a Guide for Icons:
Download a third-party icon theme. You can find many community-created icon themes on Pling.com
Right-click on the downloaded theme file and select "Extract Here"[extract-icons]
Open the app menu to enable the "Show Hidden Files" option.[hi…
system
Closed
October 5, 2024, 7:10pm
13
