@Aravisian , I am trying to create 100GB partition on my 500GB SSD. I am starting over again due to the serious login problem.
The instructions you gave me above/the link isnt working.
Here is where I'm at now. See below two screenshots. What should I do now? I want to LUKS encrypt it also.
You appear to be missing two crucial things. You need a plus sign (+) when specifying the size and you need a Unit. For example, if specifying a size of 110gigs:
Okay, so now what do i do? I really need to wipe the whole SSD, but i cant figure out how, there still a bunch of partitions, bu i did reformat all of them.
@Aravisian , now come across even more problems. It chose the partition size automatically? and it wont let me choose partition #1 like the instructions tell me to choose:
Okay, i had to delete all those partitions. And make a new one, sigh. what a headache.
It says when I type "lsblk -f" it should say "crypto_LUKS"
But it only say "crypto", it may not matter?
@Aravisian , ok, looks like i got the LUKs done/completed. When I install the ZorinOS Core into it, i guess i dont need to choose the LUKS option, because I already created an encrypted LUKS?
What would happen if i chose the LUKS option again?
Also, which partitions should i choose here?
