I am not so sure if your m/b has the same bug issue, but at least I can tell you what my BIOS settings are:
IOMMU is enabled
XHCI handoff is enabled
EHCI handoff is disabled
USB Legacy support is enabled
OS type is set to Other OS
IOMMU is enabled
mine legacy
You mean, you are trying to install in Legacy BIOS mode?
my bios is legacy
so i believe yeah
what hard drive mode
mine might be in EHCI or ATA
I checked the date of BIOS for this M/B:
2017/11/13
Judging from the date, it is a EFI M/B.
You might be using a Legacy mode, but it is capable of running EFI.
its the blue screen so i believe its legacy
Did you check the link I posted above?
Does that how your m/b look like?
I asked because I once was got a different GPU installed than the what written on the invoice by the computer shop. Since that experience I always assemble computer myself.
thats def my M/b
is there a way to enable EFI or is that pre Enabled
If there any way you take a photo of the BIOS page and post here?
What is the revision of your BIOS?
no idea
ill check System Info
I will ask a help from our senior superior level volunteer.
@Aravisian
have you ever seen Bios from 2017 comes in Legacy only?
would there be away to check if its compatible
It should be.
I am just very surprised to see Legacy BIOS on the m/b of this vintage.
ill reboot and see
Nope, that wouldn't happen. It would be UEFI.
Senior?
